No Internet access via LAN clients
Apr 28th, 2012
Hi All,
I have a Cisco 1841 router that is connected to a switch. I have WAN/LAN configured on the router and the switch is handing out internal IP's.
The issus that none of the client machines can access the Internet. From within the router console, I am able to ping external domain names, my ISP DNS servers.
Once the client machines picks up an IP they are unable to ping any external domain names or IP's and not even the ISP DNS servers, but they can ping the Cisco router IP. As a note I have tried my ISP DNS servers and as a test Google's DNS servers, but neither will allow access to the Internet.
I have checked google looking for an answer on why, but I am missing something I just don't know why. Any help would be helpful.
Ron
Below is the current running config:
Building configuration...
Current configuration : 1440 bytes
version 12.4
hostname cisco
boot-start-marker
boot-end-marker
enable secret 5 $1$qY4A$6u.zFbIIHacEB51di1Sda.
enable password astec72
no aaa new-model
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.14
ip dhcp excluded-address 10.10.10.51 10.10.10.254
ip dhcp pool SpyTraer
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 8.8.8.8 8.8.4.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
interface FastEthernet0/0
description $ETH-LAN$
ip address 10.10.10.1 255.255.255.0
ip nat inside
no ip route-cache
speed auto
half-duplex
no cdp enable
no mop enabled
interface FastEthernet0/1
description $ETH-WAN$
ip address dhcp client-id FastEthernet0/1
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 permanent
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 remark CCP_ACL Category=2
access-list 1 permit any
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password astec
login
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
Overall Rating: 4.3 (3 ratings)
Dan-Ciprian Cicioiu Sat, 04/28/2012 - 08:44
Hi Ron,
no ip routing
You might want to enable ip routing, and ip cef.
enable
conf t
ip routing
ip cef
Dan
Dan-Ciprian Cicioiu Sat, 04/28/2012 - 08:45
Also ,
ip nat inside
no ip route-cache
speed auto
half-duplex
no cdp enable
no mop enabled
Check the duplex configuration of the equipment connected to the router's Fa0/0.
Dan
blkandstrong1966 Sat, 04/28/2012 - 14:36
Hi Dan,
Thanks for the reply. I ran the command you suggested to enable ip routing. After executing the command, I am still unable to get to the Internet and now I am unable to ping any external domains for external IP's from the router. I checked as you asked for the duplex mode on the switch which is set to Auto,
One other piece of information, I am running Cisco Configuration professional and when doing a test check connection, I get an error when testing the connection which fails on pinging the destination host.
Below is the latest running config after enabling routing as you requested.
Thanks for taking the time to help me.
Ron
Current configuration : 1483 bytes
version 12.4
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip cef
   import all
   dns-server 66.18.32.2 66.18.32.3
ip name-server 66.18.32.2
ip name-server 66.18.32.3
ip flow ingress
ip flow egress
ip nat inside
speed auto
half-duplex
no cdp enable
no mop enabled
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
no cdp enable
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password astec
login
end
Jeff Van Houten Sat, 04/28/2012 - 09:44
You said the switch is handing out ips but the router has dhcp configured. What is the configuration on the switch?
blkandstrong1966 Sat, 04/28/2012 - 14:38
Hi Jeff,
You are correct. I sent the incorrect information.
The Cisco is setup as DHCP and assigning private IP's through the switch to client workstations.
Correction, the switch is not handing out IP's. Sorry for the misleading information before.
Ron
John Blakley Sat, 04/28/2012 - 14:40
You'll probably want to tighten your access list for natting and not do everything. Change it to:
Access-list 1 permit 10.10.10.0 0.0.0.255 and see if that helps.
Edit: leave ip routing on like Dan suggested. It's needed.
blkandstrong1966 Sat, 04/28/2012 - 15:44
Hi Jblakley,
Did as you suggested - output from command:
access-;ist 1 permit any
access-list 1 permit 10.10.10.0 0.0.0.255
still no Internet access or pinging any outside domain via IP including ISP dns servers.
Ron
John Blakley Sat, 04/28/2012 - 16:21
Ron,
You'll need to get rid of the permit any statement. Try this:
no access-list 1
blkandstrong1966 Sat, 04/28/2012 - 16:54
Sorry I misunderstood your previous request change.
New output shows: access-list 1 permit 10.10.10.0 0.0.0.255
Still same issues as before.
The only thing that has changed was that I added to the command for enabling routing, but since then no outside pinging.
Dan is on the right track and you are right on with ACL.
Since I am unable to ping the ISP DNS servers this is not good.
Ron
blkandstrong1966 Sat, 04/28/2012 - 17:00
Show IP Route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
66.0.0.0/32 is subnetted, 1 subnets
S     66.18.63.164 [254/0] via 108.174.105.1, FastEthernet0/1
     10.0.0.0/24 is subnetted 1 subnets
C     10.10.10.0 is directly connected FastEthernet0/0
     108.0.0.0/24 is subnetted, 1 subnets
C     108.174.105.0 is directly connected, FastEthernet0/1
S*     0.0.0.0/0 is directly connected, FastEthernet0/1
John Blakley Sat, 04/28/2012 - 17:21
Ron,
Let's try this:
change the default route to:
ip route 0.0.0.0 0.0.0.0 fa0/1 dhcp
Shut your fa0/1 interface and bring it back up.
Once you get this, try to ping:
4.2.2.1
Then try to ping that while sourcing from the inside interface. If that works, you're natting fine. If it doesn't work and the above doesn't work, something else between you and the router isn't working.
ping 4.2.2.1 source fa0/0
If that doesn't work, we'll need to get into debugging because the above looks fine. Your routing table should show a next hop though which is why we're adding the dhcp tag at the end of the default route. If your original default route doesn't go away after adding this one, go ahead and delete it and put the one above. We'll only want the one.
blkandstrong1966 Sat, 04/28/2012 - 17:56
OK I am now able to ping 4.2.2.1 from the router and from a connected client.
I am also able to ping my ISP DNS servers as well.
Issue now is that I am dropping about 40% of packets to all ping locations.
Browsing is also really, really slow.
Any idea why?
Thanks -Ron
John Blakley Sat, 04/28/2012 - 18:02
Ron,
That problem probably goes back to the half-duplex setting that you have on your internal interface. Try hard setting that to 100/full:
int fa0/0
speed 100
duple full
John
Please remember to rate all helpful posts...
Dan-Ciprian Cicioiu Sat, 04/28/2012 - 18:50
I can bet that the switch has 100 , half-duplex auto-negociated
After you check , set on the router's interface.
default speed
default duplex
Dan
blkandstrong1966 Sat, 04/28/2012 - 21:28
Hi Dan,
After running the commands you suggested I am still experncing 40% packet loss on pings and very slow Internet browsing speed.
Ron
charliediebel Sun, 04/29/2012 - 14:10
On the link between the two interfaces where the packet loss is occurring, one of two things is going on
you must have half duplex being set for some reason...which is incorrect....make absolutely sure both of the links are hard set to the same parameters...if that is not the problem, there must be something physically wrong with the fiber or copper between the two interfaces..if a fiber link...have the light levels tested at both ends to verify no more than 4db light difference between the two ends...or you will start getting errors and dropped packets.
blkandstrong1966 Sun, 04/29/2012 - 14:52
Hi Charlie,
I just ran show inf and both links are showing
Full-duplex, 100Mb/s 100BaseTX/FX
MTU 1500 bytes, BW 100000 Kbit
I have also changed out the switch that I had in place with another switch and the same speed issues remain.
Ron
John Blakley Sun, 04/29/2012 - 15:59
Ron,
Do you lose packets if you ping 4.2.2.1 from the router? Try this:
ping 4.2.2.1 rep 5000
Let me know how this goes...
John
blkandstrong1966 Sat, 04/28/2012 - 18:57
Sorry for the delay
cisco#sh int fa0/1
FastEthernet0/1 is up, line protocol is down
  Hardware is Gt96k FE, address is 0023.ebd6.7e71 (bia 0023.ebd6.7e71)
  Description: $ETH-WAN$
  Internet address is 108.174.105.127/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto Speed, 100BaseTX/FX
  Last input 00:03:58, output 00:03:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3095 packets input, 1753793 bytes
     Received 212 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     3540 packets output, 321416 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
cisco#
cisco#sh int fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0023.ebd6.7e70 (bia 0023.ebd6.7e70)
  Description: $ETH-LAN$
  Internet address is 10.10.10.1/24
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:01:41, output 00:00:03, output hang never
     9866 packets input, 1208741 bytes
     Received 1395 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     6692 packets output, 2740942 bytes, 0 underruns
     0 output errors, 41 collisions, 8 interface resets
cisco#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.10.10.0 is directly connected, FastEthernet0/0
cisco#
cisco#sh ip nat trans
Pro Inside global      Inside local       Outside local      Outside global
tcp 108.174.105.127:50105 10.10.10.18:50105 208.48.254.107:80 208.48.254.107:80
tcp 108.174.105.127:50109 10.10.10.18:50109 208.28.224.10:80 208.28.224.10:80
tcp 108.174.105.127:50317 10.10.10.18:50317 208.28.224.18:80 208.28.224.18:80
tcp 108.174.105.127:50345 10.10.10.18:50345 65.55.121.241:80 65.55.121.241:80
tcp 108.174.105.127:50347 10.10.10.18:50347 65.55.239.146:80 65.55.239.146:80
tcp 108.174.105.127:50348 10.10.10.18:50348 208.28.224.49:80 208.28.224.49:80
tcp 108.174.105.127:50427 10.10.10.18:50427 173.194.37.32:443 173.194.37.32:443
tcp 108.174.105.127:50429 10.10.10.18:50429 184.28.190.176:443 184.28.190.176:443
tcp 108.174.105.127:50434 10.10.10.18:50434 184.28.190.176:443 184.28.190.176:443
tcp 108.174.105.127:50445 10.10.10.18:50445 184.28.98.176:443 184.28.98.176:443
tcp 108.174.105.127:50447 10.10.10.18:50447 184.28.98.176:443 184.28.98.176:443
tcp 108.174.105.127:50450 10.10.10.18:50450 184.28.98.176:443 184.28.98.176:443
tcp 108.174.105.127:50501 10.10.10.18:50501 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50505 10.10.10.18:50505 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50509 10.10.10.18:50509 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50511 10.10.10.18:50511 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50513 10.10.10.18:50513 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50524 10.10.10.18:50524 184.28.212.176:443 184.28.212.176:443
tcp 108.174.105.127:50533 10.10.10.18:50533 65.54.93.17:80   65.54.93.17:80
Dan-Ciprian Cicioiu Sun, 04/29/2012 - 04:03
I would delete the static default route :
no ip route 0.0.0.0 0.0.0.0 fa0/1 dhcp
And any default route configured. The default route is automatically configured from the information received via the DHCP.
Fa0/1 is and ethernet segment and you do not have any next hop set, just the interface.
Dan
blkandstrong1966 Sun, 04/29/2012 - 18:01
Hi John and Dan,
I finally got it working. Per Dan's request to delete the static routes, I did not delete the static route, but instead I entered the forwarding next hop as the ISP gateway address (IP Address) and that fixed it.
Thank you both for your time and effort on this matter.
Ron
