Upgrade or new installation, Callmanager 7.0.2.20000-5 to 8.6?
Answered Question
Apr 28th, 2012
Hi all,
I have a CCM 7.0.2.20000-5 that should be upgraded to 8.6.
As mentioned in http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf , a direct upgrade is not possible.
I suppose an upgrade to 7.1x and then to 8.6 is not possible either, because 7.1x is EoS.
How can this be done? A new installation from 8.6 and a restore from 7.0.2?
Thanks for a hint.
Greets,
Norbert
Correct Answer by paolo bevilacqua about 5 years 2 months ago
If remember correctly, CUCM doesn't supports cross-release restore (wow).
If so, your only choice is either somehow obtain 7.1 media , or BAT export, and re-import.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sat, 04/28/2012 - 14:44
  • Hall of Fame,
    Founding Member
alig.norbert Sat, 04/28/2012 - 14:54
If I can get a 7.1 media, the licenses from the installed 7.0.2 should still be active on the 7.1, right?
Well, let's asking our cisco sales ;-)
Norbert
Jaime Valencia Sat, 04/28/2012 - 20:05
  • Cisco Employee,
  • Hall of Fame,
    2011
Paolo is correct, CUCM restores have always been on the EXACT (all the way to ES, SRs, etc) same version from which the backup was taken.
If you're going to do this all in one step you do not need any 7.1 licenses, once you upgrade to 7.1 you can immediately upgrade to 8.6 and then install the new licenses.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
