Warning message
creating layer 3 SVI
Apr 29th, 2012
HI guys, I have an issue with my cisco 851W router
when I try to configure fast ethernet port , I keep getting an error:
IP addresses may not be configured on L2 links
according information from the forum I have to :
conf t
int <interface name/no>
no switchport mode
ip address x.x.x.x x.x.x.x
it`s still getting the error
or if you want the port to be a member of VLAN, do this-->
conf t
int vlan <no>
switchport access vlan <vlan name/no>
for instance if the internet comes via cable from 192.168.66.101 255.255.255.0
I have to configure
conf t
int vlan 1
ip address 192.168.66.101 255.255.255.0
int fastethernet 0
switchport access vlan 1
is this correct?
thanks in advance for your help
best regards
mahmoodmm Sun, 04/29/2012 - 00:59
Just create create the SVI and connect the connection on any port as by default all the ports are in vlan 1.
penevsquare Sun, 04/29/2012 - 02:00
thank you very much indeed for your fast reply
the configuration should be:
R1#conf t
R1(config)#int vlan 1
R1(config-if)#ip address 192.168.66.101 255.255.255.0
R1(config)#interface fastEthernet 0
R1(config-if)#switchport mode access
R1(config-if)#switchport access vlan 1
R1(config-if)#no shut
thanks in advance
best regards
mahmoodmkl Sun, 04/29/2012 - 03:29
  • Gold, 750 points or more
Hi.
Yes this should be enough.
Related Content
