IP phone disconnected when i did physical reset
Apr 29th, 2012
                   Gents,
When i unplug and plug any ip phone direct connected to 3750 switch with IOS 3750-advipservicesk9-mz.122-46.se.bin, the phone get disconnected power.
To fix the issue, i have to do physical switch reset.
Where is the problem? is it on the switch IOS or something else? i recently did the F/W upgrade on the phones to the Cisco latest.
BR,
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 04/29/2012 - 04:44
  • Hall of Fame,
    Founding Member
Update switch IOS and check port configuration.
William Bell Sun, 04/29/2012 - 05:57
  • Purple, 4500 points or more
When the error condition occurs, are you seeing anything logged to syslog or the local log on the switch? You may need to reconfigure logging to see log messages.
Can't really speculate further without more information.
Bill
blog: http://ucguerrilla.com
Related Content
