ACS 5.3 - "application failed to start"
Apr 29th, 2012
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Although, ACS states its installed, after going through the startup. However when I do show application nothing comes up. When I do a application start acs, %Application failed to start.
I reinstalled 4 times, same results.
Anyone have any feedback?
thanks!
BTW - I RATE HELPFUL POST!
Overall Rating: 3 (1 ratings)
Scott Fella Sun, 04/29/2012 - 10:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
George,
Are you running this on VM or an appliance?
Scott Fella
Sent from my iPhone
George Stefanick Mon, 04/30/2012 - 20:54
Hey Scott,
ESXi... Sorry I should have mentioned that ...
Tarik Admani Wed, 05/02/2012 - 00:45
  • Green, 3000 points or more
George,
Can you please post the output of "show application" along with "show application status acs"?
Since this in on VM what are the specs? Are you setting this up for POC or initial install. Also can you check the iso you downloaded and compare it against the md5sum posted on cco? Also did you run through the initial setup?
I dont mean to ask some basic questions, i just want to get an idea to see whether the setup program launched or not.
tarik Admani
George Stefanick Wed, 05/02/2012 - 12:20
Tarik,
Thanks for your reply. I will be so gald to get this issue behind me...
I'm not in front of my server at the moment. But when I do show application, there is nothing even with show application status acs. Its like it didnt install, although I went through the setup steps.
VM -- I tried a few different setups. Linux 32/OS. 4 gig ram, 60 gig hd.
I didnt check the MD5, but I will. Where will I find the MD5 in the file, properties? Sorry, never had to check that before.
please ask away!
Tarik Admani Thu, 05/03/2012 - 06:17
George,
You can find the md5 sum in the download section when you are ready to download the file.
Also try using rhel 4 32 bit, also what version of esx are you using?
Tarik Admani
George Stefanick Thu, 05/03/2012 - 06:47
Tarik,
Silly question, but what do I check the MD5 against ?
Ok, I will give that a shot. Wont be till Sunday.
ESXi 5
edondurguti Fri, 05/04/2012 - 08:27
I had some issues installing a VM instance of ACS 5.3 demo.
I am currently doing it for lab purposes only and here is my setup and works fine.
I use VMware Player and the OS is:
Other Linux - 32bit
60GB hdd and 4GB RAM - it would not start the application before I did that and oh yeah 2 core cpu don't forget the CPUs, cuz I did and it didn't work
so
60GB HDD
4GB RAM
2  CORE CPU
