IPV6 QoS Low Latency Queuing for voice support on routers
Apr 30th, 2012
                   Hi, with IPV4 you use CBWFQ with a Priority queue for voice (marked EF) traffic. However priority queuing is not supported for IPV6 traffic on routers such as the G2's (29xx, 39xx), so what are the alternative LLQ queuing mechanisms for an outbound QoS policy to give low latency? Seaching CCO I can find nothing on this subject.
Mick Russell
Dan-Ciprian Cicioiu Mon, 04/30/2012 - 04:23
Hi Russell,
Do you have any document/link that states the G2 does not support queuing for IPv6 traffic ? On the data sheet is not mentioned something like this
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78_553924.html
Did you try :
class-map ipv6-voice
  match protocol ipv6
  match dscp ef
policy-map LLQ
    class ipv6-voice
         priority 25
Dan
mrrussell Tue, 05/01/2012 - 04:12
Dan, yes I did see the use of classifying ipv6 traffic, but thought this would not work with a priority queue. I have just tried it and it does work. So now I have two priority queues in my policy-map, one for IPV4 and one for IPV6.
class-map match-all ipv6-voice
match protocol ipv6
match dscp ef
class-map match-any ce_ef_output
Mick
match ip dscp cs5 ef
Policy outbound
Description QoS policy for 5 VLANS  42.5 Mbit/s per access cdr 42.5 - 12 %EF -layer 1 Kbit/s EF 3079 AF 7528 DE 3346
! - 90% ipv4 10% ipv6
class ce_ef_output
  police 3550500 27000 27000 conform-action set-dscp-transmit EF exceed-action set-dscp-transmit EF violate-action drop
  priority 3550
class ipv6-voice
  priority 394
  police 394500 3000 3000 conform-action set-dscp-transmit EF exceed-action set-dscp-transmit EF violate-action drop
class ce_af4_output
bandwidth 7865
etc
