Warning message
Multilink PPP not showing correct bandwidth
Apr 30th, 2012
I am trying to use MPPP to combine 2 T1 circuits.
I have configured everything and I can successfully ping the router interface of the distant router. The problem that I am having is that when I do a Show ppp multilink command the total bandwidth that is displaying is 128k and not 3072MB from combinig 2 t1 circuits together.  Am i missing something?
Any help is appreciated.
Overall Rating: 5 (2 ratings)
John Blakley Mon, 04/30/2012 - 08:23
  • Purple, 4500 points or more
Do you have any bandwidth statements on either the MLP interface or any of the serials? If so, take those off and it will adjust the rate automatically...
HTH,
John
Desmond Smith Mon, 04/30/2012 - 08:38
Hi John,
I took off the bandwidth statements and it is still displaying totall bandwidth 128.
John Blakley Mon, 04/30/2012 - 09:02
Can you post the serial interface configs, mlp config and "sh int mul"
Desmond Smith Mon, 04/30/2012 - 10:12
Multilink5
Bundle name:
Remote Endpoint Discriminator: [1] remotetest_2911
Local Endpoint Discriminator: [1] test_2911
Bundle up for 00:58:43, total bandwidth 128, load 1/255
Receive buffer limit 24000 bytes, frag timeout 1500 ms
   0/0 fragments/bytes in reassembly list
   0 lost fragments, 0 reordered
   0/0 discarded fragments/bytes, 0 lost received
   0x39 received sequence, 0xEA sent sequence
Member links: 2 active, 2 inactive (max 255, min not set)
   Se0/2/1:0, since 00:58:43
   Se0/2/0:0, since 00:58:43
   Se0/3/1:0 (inactive)
   Se0/3/0:0 (inactive)
No inactive multilink
2911#sh run
Building configuration...
card type t1 0 2
card type t1 0 3
security passwords min-length 8
logging buffered 51200 warnings
logging console critical
aaa session-id common
network-clock-participate wic 2
network-clock-participate wic 3
no ipv6 cef
no ip source-route
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip multicast-routing
no ip domain lookup
ip domain name noaa.gov
ip cef
controller T1 0/2/0
clock source internal
cablelength short 110
channel-group 0 timeslots 24
controller T1 0/2/1
controller T1 0/3/0
controller T1 0/3/1
interface Multilink5
description Multilink PPP Connection
ip address 172.18.x.11 255.255.255.0
no ip redirects
no ip proxy-arp
ip pim dense-mode
no ip route-cache
ppp multilink
ppp multilink group 5
no cdp enable
no clns route-cache
interface Serial0/2/0:0
no ip address
no ip redirects
no ip proxy-arp
ip pim dense-mode
encapsulation ppp
no ip route-cache
ppp multilink
no clns route-cache
interface Serial0/2/1:0
no ip address
no ip redirects
no ip proxy-arp
ip pim dense-mode
encapsulation ppp
no ip route-cache
ppp multilink
no clns route-cache
interface Serial0/3/0:0
no ip address
no ip redirects
no ip proxy-arp
ip pim dense-mode
encapsulation ppp
no ip route-cache
ppp multilink
no clns route-cache
interface Serial0/3/1:0
no ip address
no ip redirects
no ip proxy-arp
ip pim dense-mode
encapsulation ppp
no ip route-cache
ppp multilink
no clns route-cache
Joseph W. Doherty Mon, 04/30/2012 - 09:42
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What does show interface show for bandwidth for the bonded interface?
Desmond Smith Mon, 04/30/2012 - 10:13
Joseph,
The bandwidth for the multilink interface also states 128Kbit.
John Blakley Mon, 04/30/2012 - 10:39
Desmond,
I think the problem is with your channel-group config and you're only telling it to use 1 64k channel. Create an outage window and change it to:
Channel-group 0 timeslot 1-24
For both controllers.
Hth,
John
Desmond Smith Mon, 04/30/2012 - 11:10
John,
Thanks for the help, that was it!
I looked through the config multiple times and I subconciously thought it said 1-24 but it never registered.
Thanks for keep some grey hair off my head!!!
Desmond
John Blakley Mon, 04/30/2012 - 11:25
No problem and thanks for letting us know!
Please rate all useful posts
Desmond Smith Tue, 05/01/2012 - 06:50
John,
I also have an additional issue with the link from yesterday. THe TXload is 255/255 when I perform a basic ping to the distant router interface, any ideas?
Related Content
