ISE and NAC Agent
Apr 30th, 2012
Hello, we currently run NAC for our wired (OOB), wireless (IB) and VPN (IB) enviroments. We are looking at migrating over to ISE for our wireless enviroment as a first step, with follow-up projects to move the VPN and wired clients over. I have been reading that ISE will still use the NAC agent. Our current NAC enviroment is at 4.7.2 and we are running the 4.7.2.10 agent. We do not want to upgrade this enviroment, we would rather focus on migrating to ISE. So our thought was to upgrade the clients to the latest NAC agent version 4.9.1.5. This agent is supported against the 4.7.2 NAC Manager. The problem is, I do not see this agent version listed as supported in the ISE compatibility matrix. Instead, they list a NAC agent of 4.9.0.37, which ironically, is NOT listed in the NAC compatiblity matrix. So what version of NAC agent should we run in a mixed enviroment? I am hoping 4.9.1.5 is supported against ISE, and the matrix is simply not updated yet. Thank you in advance for your help.
Tarik Admani Tue, 05/01/2012 - 06:21
The nac agents will not work together, you will have to upgrade your environment to support the same agent version for both environments.
thanks,
Tarik Admani
jthullen Tue, 05/01/2012 - 06:40
Not sure I understand. The 4.9.1.5 NAC agent does run against our CAM, as we have tested that and it is listed in the support matrix. So if we upgrade our NAC applainces, we would still run that agent. Does that agent tun against ISE, and if not, what is Cisco's recommendation to bring ISE into the enviroment? We have to have a migration path, and wireless seemed like a logical first step. But we need a NAC agent that will work against Clean Access AND ISE as our laptops will be wireless and wired at different times. Which Agent would be recommended?
Tarik Admani Wed, 05/02/2012 - 00:38
I am following up on this for your, I am confirming to see if the ISE documentation needs to be updated or if it hasnt been officially tested. I completely understand why this is critical.
Tarik Admani
jthullen Wed, 05/02/2012 - 04:49
Thank you Tarik, I really appreciate your help with this issue. Hopefully there is a client compatibile with both, I will keep my fingers crossed until I hear from you!.
Eduardo Aliaga Mon, 08/06/2012 - 10:51
Hello everybody. Are there any updates about the agents compatibility issue between ISE and NAC manager ?
