IKE Initiator unable to find policy: Intfc inside
Apr 30th, 2012
I am testing VPN tunnels in a lab. I have the following (simple) setup:
  -one ASA5505 has an "inside" interface with address 192.16.99.40/24 and an "outside" interface with address 205.192.0.2/24
  -one computer with address 192.16.99.1/24 ("Client") is connected to the "inside" interface
  -one ASA5510 has an "inside" interface with address 192.0.99.40/24 and an "outside" interface with address 205.192.0.1/24
  -one computer with address 192.0.99.1/24 ("Server") is connected to the "inside" interface
  -both "outside" interfaces are connected through a layer 2 switch
I had a VPN tunnel between them using "Main mode", and that worked without a problem.
But in my target system, the ASA5505 will be connected to a router with a dynamic IP address, and so I need to use "Aggressive mode", where the ASA5510 will have a static address on the "outside" interface. The ASA5505 will therefore initiate the VPN session.
I am using the ASDM, by the way.
I have the VPN tunnel established, but I am unable to ping from either side.
When I ping the Server from the Client, the ASA5505 gives me the expected "Built/Teardown ICMP connection...", but the ASA5510 says "IKE Initiator unable to find policy: Intf inside, Src: 192.0.99.1, Dst: 192.16.99.1". So the ping makes it to the Server, but the reply can't find its way back out.
When I ping the client from the Server, I get the same message on the ASA5510: "IKE Initiator unable to find policy: Intfc inside, Src: 192.0.99.1, Dst: 192.16.99.1".
I attach the configuration on the ASA5510.
I checked similar posts, but the root problem seemed to be different.
Any help is welcome.
thanks,
Pedro
Overall Rating: 5 (1 ratings)
suhas_syndrome Wed, 07/31/2013 - 07:14
Hi Mohammad,
  I am running into the same problem.
My ASA on HUB location & 3 spoke end fortigate. i have configured one static site-to-site vpn that is working fine but another two are dynamic vpn tunnel one is showing up and another is not
iam getting error
%ASA-3-713042: IKE Initiator unable to find policy: Intf
interface_number, Src: source_address, Dst: dest_address
i have shre below output & running configuration.
tunel status
ciscoasa# show isakmp sa
   Active SA: 2
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 2
1   IKE Peer: 159.148.115.132
    Type    : L2L             Role    : responder
    Rekey   : no              State   : AM_ACTIVE
2   IKE Peer: 117.219.148.69
ciscoasa#
Session Type: LAN-to-LAN
Connection   : 159.148.115.132
Index        : 44                     IP Addr      : 159.148.115.132
Protocol     : IKE
Encryption   : 3DES                   Hashing      : SHA1
Bytes Tx     : 0                      Bytes Rx     : 0
Login Time   : 11:16:07 UTC Wed Jul 31 2013
Duration     : 0h:26m:21s
Connection   : ckgs-indr
Index        : 45                     IP Addr      : 117.219.148.69
Protocol     : IKE
Login Time   : 11:32:15 UTC Wed Jul 31 2013
Duration     : 0h:10m:13s
ciscoasa#
*************config*******************
Result of the command: "sho run"
: Saved
ASA Version 8.2(4)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 10.71.11.0 VPN_Add
name 10.96.11.0 lan_10.96.11.0
name 10.19.1.0 vpn_pool
name 10.132.6.0 SWED
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 115.114.107.11 255.255.255.248
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.21.5.240 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
boot system disk0:/asa824-k8.bin
ftp mode passive
dns domain-lookup outside
dns domain-lookup inside
object-group network DM_INLINE_NETWORK_1
network-object VPN_Add 255.255.255.0
network-object lan_10.96.11.0 255.255.255.0
access-list outside_cryptomap_65535.1 extended permit ip 10.21.0.0 255.255.0.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip 10.21.0.0 255.255.0.0 VPN_Add 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.21.0.0 255.255.0.0 lan_10.96.11.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.21.0.0 255.255.0.0 host vpn_pool
access-list inside_nat0_outbound extended permit ip 10.21.5.0 255.255.255.0 vpn_pool 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.21.0.0 255.255.0.0 SWED 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit ip 10.21.0.0 255.255.0.0 any
access-list cnk standard permit 10.21.0.0 255.255.0.0
access-list outside_access_in extended permit icmp any any
access-list outside_nat0_outbound extended permit ip VPN_Add 255.255.255.0 lan_10.96.11.0 255.255.255.0
access-list outside_nat0_outbound extended permit ip lan_10.96.11.0 255.255.255.0 VPN_Add 255.255.255.0
access-list ipsce_vpn_splitTunnelAcl standard permit 10.21.5.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 10.21.0.0 255.255.0.0 SWED 255.255.255.0
access-list smart-tunnel webtype permit tcp 10.21.0.0 255.255.0.0 eq telnet log default
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool vpn_cnk_ssl 10.19.1.1-10.19.1.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.21.0.0 255.255.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 115.114.107.9 1
route inside 10.21.0.0 255.255.0.0 10.21.5.6 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 1 match address outside_cryptomap_65535.1
crypto dynamic-map outside_dyn_map 1 set transform-set ESP-3DES-SHA
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 159.148.115.132
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 65534 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 28800
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-3.1.03103-k9.pkg 2
svc image disk0:/anyconnect-macosx-i386-3.1.03103-k9.pkg 3
svc enable
tunnel-group-list enable
smart-tunnel list server 1 telnet platform windows
smart-tunnel list server 1 tcp/telnet platform windows
smart-tunnel auto-signon serverlist ip 10.21.5.0 255.255.255.0
group-policy DfltGrpPolicy attributes
group-policy GroupPolicy_static internal
group-policy GroupPolicy_static attributes
vpn-idle-timeout 30
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
group-policy ipsce_vpn internal
group-policy ipsce_vpn attributes
dns-server value 8.8.8.8 4.2.2.2
vpn-tunnel-protocol IPSec svc
split-tunnel-policy tunnelspecified
split-tunnel-network-list value ipsce_vpn_splitTunnelAcl
group-policy cnk_ssl internal
group-policy cnk_ssl attributes
vpn-tunnel-protocol svc webvpn
split-tunnel-network-list value cnk
default-domain none
webvpn
  filter value smart-tunnel
  smart-tunnel auto-start server
username user1 password Ttlh3sZkia0/P8q. encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
tunnel-group ckgs_goa type ipsec-l2l
tunnel-group ckgs_goa ipsec-attributes
pre-shared-key *****
tunnel-group ckgs-indr type ipsec-l2l
tunnel-group ckgs-indr ipsec-attributes
tunnel-group cnk_ssl type remote-access
tunnel-group cnk_ssl general-attributes
address-pool vpn_cnk_ssl
default-group-policy cnk_ssl
tunnel-group cnk_ssl webvpn-attributes
group-alias cnk_ssl enable
group-url https://115.114.107.11/cnk_ssl enable
tunnel-group ipsce_vpn type remote-access
tunnel-group ipsce_vpn general-attributes
default-group-policy ipsce_vpn
tunnel-group ipsce_vpn ipsec-attributes
tunnel-group 159.148.115.132 type ipsec-l2l
tunnel-group 159.148.115.132 general-attributes
default-group-policy GroupPolicy_static
tunnel-group 159.148.115.132 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:692294c06b6a801bba4af60af33b8fe4
: end
SuhasB.
tim.knipper Tue, 05/15/2012 - 10:03
I just ran into an issue with the same message.  My problem was that there was another tunnel setup with the same remote end IP address.  So there were two tunnels with the same destination subnet on two separate crypto maps and the firewall didn't know which tunnel to send them across.
Related Content
