ACS - cisco-av-pair
li_xiao_li
Hi Sir,
I have some doubts about the attribute in ACS: cisco-av-pair. I setup some ACLs in this attribute and hope this attribute can be sent from ACS to my PIX/ASA for future filtering usage if an user passes the first authentication attempt. I found that this attribute can not be installed in the PIX (when I checked the PIX using 'show access-list') even though the user passes the authentication. What is the reason?
Eduardo Aliaga
Level 4
Level 4
ASA do support downloadable access-lists. Old versions of PIX software do it in a different way. Could you please tell us what ASA or PIX version are you using ?
li_xiao_li
I am using ASA8.0 software. I also tried to use 'downloadable ACL' attribute, this attribute does the job as its name says. But cisco-av-pair cannot. Is there another possible reason?
Thanks.
