Cisco router Site-to-Site dvti VPN Configuration
May 1st, 2012
HI
Acc i am trying to deploy site to site dynamic vti vpn
i send you my toplogy and config too
its is not working can any please tell me where i am worng..
thankyou
R1#sh run
Building configuration...
Current configuration : 1707 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
crypto keyring myvpnkey
  pre-shared-key address 14.1.1.2 key cisco2
  pre-shared-key address 13.1.1.2 key cisco1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 7200
crypto isakmp profile myisakmp
   keyring myvpnkey
   match identity address 13.1.1.2 255.255.255.255
   match identity address 14.1.1.2 255.255.255.255
   virtual-template 1
crypto ipsec transform-set newt ah-sha-hmac esp-3des esp-sha-hmac
crypto ipsec profile myipsec
set security-association lifetime seconds 7200
set transform-set newt
set pfs group2
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 11.1.1.1 255.0.0.0
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Virtual-Template1 type tunnel
ip unnumbered Serial0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile myipsec
router rip
network 14.0.0.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 11.1.1.2
ip http server
no ip http secure-server
when i run sh ip int b then i see my Virtual-Template1 is down
R1 #sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.2.1     YES NVRAM  up                    up
Serial0/0                  11.1.1.1        YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/1                  unassigned      YES NVRAM  administratively down down
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Template1          11.1.1.1        YES TFTP   down                  down
and the spoke config is
R5#sh run
*Mar  1 01:29:41.851: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1430 bytes
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
archive
log config
  hidekeys
encr 3des
group 2
lifetime 7200
crypto isakmp key cisco2 address 11.1.1.1
set pfs group2
interface Tunnel0
tunnel source Serial0/0
tunnel destination 11.1.1.1
ip address 200.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 14.1.1.2 255.0.0.0
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 14.1.1.1
ip route 192.168.2.0 255.255.255.0 Tunnel0
ip http server
control-plane
olpeleri Tue, 05/01/2012 - 22:56
At first glance:
On the spoke, tunnel mode ipsec ipv4 and tunnel protection is missing under tunnel0
