cisco 877 wireless
May 1st, 2012
hi,
i would like to configure the wireless access on the cisco 877 router either on command line or gui - can anyone help me pls ?
also, does the wireless authentication and SSID  has to be local or can i put the cisco 877 on h-reap mode and connect back to my controllers in head office and use the same SSID as in my head office ? if this can be done can anyone please let me know how to do
Network Pro Wed, 05/02/2012 - 03:55
thanks for this. so if i set it to wpa2 enterprise will i be able to use the ACS cntrollers in the head office or does it need to be local authentication ?
also you mentioned it cant connect back to central wlc but you mentioned about using same ssid, is this for consistency ?
Stephen Rodriguez Fri, 05/04/2012 - 03:52
  • Purple, 4500 points or more
Yes so long as there is connectivity back to HQ then you cause those AAA servers
For the SSID yes, it's for consistency. That way the user or IT) doesn't have to maintain two profiles for wireless on the laptops.
Steve
Network Pro Fri, 05/04/2012 - 04:46
thanks very much stephen
couyld you please post the config for wpa 2 enterprise as i cant seem to find it
also i am planning to use the same vlan for wired and wireless users since its just a few users - so what will be the config in this case ?
Network Pro Fri, 05/04/2012 - 08:10
will this work for 877 router as it says 1200 access points ? if it does i will give it a try and come back to you next week
Thanks for your help
Network Pro Tue, 05/15/2012 - 04:23
I am trying to authenticate with ACS server. in the above link iut says:
(i have highlighted the part which i dont understand as it says group rad_eap - does this mean all the users have to be in this group? where will this group reside in the AD, local router or ACS ?)
AP(config)#aaa group server radius rad_eap
AP(config-sg-radius)#server 10.0.0.3 auth-port 1645 acct-port 1646
AP(config-sg-radius)#exit
AP(config)#aaa new-model
AP(config)#aaa authentication login eap_methods group rad_eap
AP(config)#radius-server host 10.0.0.3 auth-port 1645
acct-port 1646 key labap1200ip102
AP(config)#end
AP#write memory
AP(config)#interface dot11radio 0
AP(config-if)#ssid labap1200
AP(config-if-ssid)#authentication open eap eap_methods
AP(config-if-ssid)#authentication network-eap eap_methods
AP(config-if-ssid)#end
AP#write memory
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
