LED light on AP
May 1st, 2012
  I have a question on Wireless AP's. We have 2 controllers, a 5508 that supports 50 AP's and a 4402 that supports 25 AP's. I have mutable AP"s but the one that I'm having a problem with is an AIR-CAP3502I-A-K9.
On the 4402 I'm running IOS AIR WLC4400-K9-7-0-230-0
On the 5508 I'm running IOS AIR-CT5500-K9-7-2-103-0
My problem is when i move a AP from the 5508 to the 4402 everything seems to work, the new IOS is downloaded to the AP and it restarts and shows up in the Wireless tab and users can hook up through it to the controller and all seems to work. The problem is that the LED light on the AO goes out once the load is finished and does not come back on. If I put it back toe the 5508, after it reloads the IOS the light comes back on and works, green or blue as the case may be. If i move it back to the 4402 it doesn't work after the load is finished. Any suggestions would help.
Leo Laohoo Tue, 05/01/2012 - 14:46
CLI into the WLC and enter the command "config ap led-state enable all".
See if this helps.
Related Content
