Enable Ping Signature on cisco IPS
Answered Question
May 1st, 2012
I have enabled signature for ping  2000 and 2004 and i have set them sev to high still i am not get alert.
I also did nmap attack and it give alert
how can i achieve this ?
thanksssssssssss
Correct Answer by sawgupta about 1 year 11 months ago
Yes using IDM you can select multiple signatures and right-click -> Enable.
Sawan Gupta
Correct Answer by ruppala about 1 year 11 months ago
Signature 2000-0 triggers on ICMP Echo Replies and 2004-0 triggers on ICMP Echo Requests.  Note that these are
extremely common network traffic. If you have enabled and unretired the sigs and if the sigs fire when tested using NMAP, they seem to be working fine. May be theres some other device on your network thats blocking such packets.
Correct Answer by Todd Pula about 1 year 11 months ago
2000 and 2004 are retired by default now.  You will need to make sure that you both enable and unretire these signatures before testing.
Average Rating: 5 (3 ratings)
Correct Answer
Todd Pula Wed, 05/02/2012 - 14:23
Correct Answer
ruppala Fri, 05/04/2012 - 16:43
alkabeer80 Sat, 05/05/2012 - 00:51
thx Todd Pula and ruppala,
i enable the signature and unretire it it is working, i want to ask why the signature get retired ????
another question i have alot of signature that is not enabled i want to enable all of them for alerting, can i do it without going to each single one and enable it i.e is there anyway (like script) i can u se to enable all of them in one time ???
thankssssssssssssssssssssssssssssssss
sawgupta Sun, 05/06/2012 - 03:59
Unretiring and enabling many signatures would have a performance impact. Only unretire and enable those signatures which are really important.
Sawan Gupta
alkabeer80 Sun, 05/06/2012 - 12:00
thx sawan,
what about enabling more than one signature for alerting (config. from CLI) is this applicable ?
thankssssssssssss
sawgupta Sun, 05/06/2012 - 17:53
Yes, enabling a few signatures is fine.
Sawan Gupta
alkabeer80 Sun, 05/06/2012 - 21:11
thx sawan, i think i did not explain what is my problem exactly.
i have 1000 signature in IPS (not enabled), i want to enable all of them, i dont want to pass all of them one by one and enable it.
Is there away i can do it, may be some command i can issue ???
Correct Answer
sawgupta Sun, 05/06/2012 - 21:26
Sawan Gupta
andreasentali Mon, 10/21/2013 - 00:48
Un-retire the echo request signature (signature 2004, subsig ID 0), enable it and change the signature action to
alert, and drop.
R1(config)# ip ips signature-definition
R1(config-sigdef)# signature 2004 0
R1(config-sigdef-sig)# status
R1(config-sigdef-sig-status)# retired false
R1(config-sigdef-sig-status)# enabled true
R1(config-sigdef-sig-status)# exit
R1(config-sigdef-sig)# engine
R1(config-sigdef-sig-engine)# event-action produce-alert
R1(config-sigdef-sig-engine)# event-action deny-packet-inline
R1(config-sigdef-sig-engine)# exit
R1(config-sigdef-sig)# exit
R1(config-sigdef)# exit
Do you want to accept these changes? [confirm]
andduart Sun, 10/27/2013 - 21:45
Maybe as a personal suggestion you can use the summary option for these type of signatures so you wont see or get all the alerts, you can have a summary of them at a time to have some of them fired
Login or Register to take actions
Posted May 1, 2012 at 9:01 PM
Stats:
Replies:11 Avg. Rating:5
Views:2089 Votes:0
Shares:0
Related Content
Discussions Leaderboard
Rank Username Points
1 816
2 668
3 603
4 526
5 367
