problem with dhcp snooping database
May 2nd, 2012
Hello All,
I want to create the dhcp snooping database using the tftp Server from our running LMS4.1 Installation. LMS is installed on Windows 2008 Server and the first problem is how to get the Windows URL c:\program files (x86)\CSCOpx\tftpboot\dhcp_snooping_database in IOS.
The ip dhcp snooping database tftp: command does not accept blanks and ( ) ...
Next problem may be acces control, do I need to configure special permissions to access the LMS4.1 tftp server???
Any help will be highly appreciated
Werner
Overall Rating: 4 (1 ratings)
Ton V Engelen Wed, 05/02/2012 - 06:03
  • Bronze, 100 points or more
you ll have to configure the tftp server to have its path settings correct
We use a linux server and created /var/tftpboot and configured the tftp server with this path
Then i configure the switch to write its dhcp snooping db to the linux server
Config line on the switch looks like this:
ip dhcp snooping database tftp://10.1.134.42/switch1.txt where switch1.txt is the db file
Then allow the file to be overwritten on the server for both the tftp server and the file itsself
So most work will be on the tftp server but it works like a charm.
I have another example for windows:
I have a tftp server and i configure it to use the upload and download directory C:\backup
So the tftp server knows what its root directory is.
In a switch i only have to point to the ip address of the tftp server (like (tftp 10.1.1.10/backup.txt ) and a filename and the file will succesfully arrive in the download directory.
Related Content
