05-02-2012 06:23 AM - edited 03-07-2019 06:27 AM
Nothing happens when we plug a USB Flash Drive into an SUP7L-E USB port. Does anybody know if this works?
Manuel
05-02-2012 07:21 AM
Manuel,
Please refer to the documentation:
Edison
05-02-2012 07:34 AM
Then this should work :
« A standard USB 2.0 device such as a flash memory device can plug into this connector. »
Is there only a specific typ supported ?
Manuel
Gesendet: Mittwoch, 2. Mai 2012 16:22
An: Linder Manuel (CASSARiUS AG)
Betreff: - Re: Cisco Supervisor 7L-E USB Port is not working
Home<>>
created by Edison Ortiz<> in LAN, Switching and Routing - View the full discussion<>>>
05-02-2012 07:46 AM
Try formatting the USB with FAT32.
05-02-2012 05:06 PM
Yes it will work and it will depend entirely on the following factors:
1. NOT ALL USB are supported. The best way to check is insert the USB stick and perform the command "sh log". If you get the log entry in the words like "USB inserted" and nothing negative then it's going to work;
2. Format using FAT16;
3. Sup7? I didn't have the chance to test but it should support up to 8 to 16 Gb size USB sticks.
