Nexus 5548UP Downgrade from 5.1.3.N1.1 to 5.0.3.N2.2b fails -- SRG file not present/cannot be opened
May 2nd, 2012
I am attempting to downgrade from 5.1.3.N1.1 to 5.0.3.N2.2b for standards compliance.
When following the ISSU steps for validation of the install all command I receive the following error on the following command:
sh install all impact kickstart bootflash:n5000-uk9-kickstart.5.0.3.N2.2b.bin system bootflash:n5000-uk9.5.0.3.N2.2b.bin
Verifying image bootflash:/n5000-uk9-kickstart.5.0.3.N2.2b.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.5.0.3.N2.2b.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.5.0.3.N2.2b.bin.
[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).
I followed some recommendations from this post https://supportforums.cisco.com/thread/2108814
  • reload to clear temp and cache
  • show system internal flash
  • checked md5sum of image
I found this information http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/deferral/Deferral_Advisory_Notice_N5K.html
I am unsure of how to upgrade when the steps to validate indicate a problem with the upgrade/downgrade.
I still receive the error.
Any help would be greatly appreciated.
Attached are the steps done so far and outputs.
catbrownhd Wed, 05/02/2012 - 10:45
Update: I am able to downgrade to 5.0.3.N1.1b with no issues.
This appears to be an issue with going from N1 to N2.
Can any elloborate on this?
Oleksandr Nesterov Fri, 05/04/2012 - 09:19
Hello Heath
Please open a TAC case to work on this - there may be many reasons for such behavior.
Also  as Krun proposed - you can set boot variables manually, then reload the  switch. And after that do not forget to run "install all" command to  ensure that everything has downgraded properly.
HTH,
Alex
krun_shah Wed, 05/02/2012 - 17:30
You can set boot variable manually and reload switch
vdsudame Fri, 05/04/2012 - 09:32
can you please send us output of following
  show system internal dir /var/tmp
also we dont recommend to change boot variables and reload.
This might cause some other problems after you downgrade.
We would rather fix the problem first and then downgrade
using install all.
Vinayak
Cisco TAC
catbrownhd Fri, 05/04/2012 - 11:50
I had already created a case with our reseller.  The engineer there had me reload the 5ks and attempt the show install all impact again.  When I did it was successful.
I was able to then downgrade to 5.0.3.N2.2b.  I am currently working to duplicate the issue by going back to 5.1.3.N1.1.
The engineer also stated that I was probably running into this bug:
CSCsw25835">http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method...
Here is the contents of the sh system internal flash and show system internal dir /var/tmp:
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/                            409600     72564      337036     18   /dev/root
/proc                             0         0           0      0   proc
/post                          2048         4        2044      1   none
/var                         409600     72564      337036     18   none
/sys                              0         0           0      0   none
/isan                       1536000    409628     1126372     27   none
/var/tmp                     307200        72      307128      1   none
/var/sysmgr                 1024000         0     1024000      0   none
/var/sysmgr/ftp              409600        68      409532      1   none
/var/sysmgr/ftp/cores        102400         0      102400      0   none
/callhome                     61440         0       61440      0   none
/dev/shm                     524288    126552      397736     25   none
/volatile                    153600         0      153600      0   none
/debug                        20480         0       20480      0   none
/dev/mqueue                       0         0           0      0   none
/debugfs                          0         0           0      0   nodev
/mnt/plog                     49024      1300       47724      3   /dev/mtdblock2
/mnt/cfg/0                   114909      4274      104702      4   /dev/sda5
/mnt/cfg/1                   112920      4274      102816      4   /dev/sda6
/var/sysmgr/startup-cfg      409600      2104      407496      1   none
/dev/pts                          0         0           0      0   devpts
/mnt/pss                     114917      5923      103060      6   /dev/sda4
/bootflash                  1609984    779460      748740     52   /dev/sda3
        ./         640
                                                               ../         240
                                                   bootloader_ver            0
                                           util_cli_history_admin           48
                                                            mysrg         1664
                                                    mcm_ascii.log         1019
                                                 m2rib_ascii.3248           68
                                                           arping          101
                                                        stp.log.1         3836
                                                         fwm1.out            0
                                                    cmp_slot_id.1            0
                                                           ntpd_1            0
                                                     ntp_client_1            0
                                                 ntp__libdapi.log            0
                                                 igmp_restart.log            0
                                                 radius_debug.log          232
                                                      cfs_mac.log          166
                                                       climib.log         1416
                                                          lcc.log          694
                                                  security_stderr           77
                                                  security_stdout            0
                                                    aaa_debug.log          519
                                               security_debug.log          647
                                                        evmc.3005           31
                                                       idehsd.log          602
                                                        mvsh.3000            0
                                                        lockcisco            0
                                                          .flexlm/          60
                                                             [email protected] 20
                                                  first_setup.log         2981
                                                  boot_uptime.log           56
                                                              vsh/          40
vdsudame Fri, 05/04/2012 - 12:13
I am assuming this output you sent me is after the reload ? Did you collect this before the reload? Also that bug is not really a bug, it just documents the condition for which we see the problem. ie if the files in one of the directories are full then it impacts the upgrade/downgrade. The action plan would be to get with Cisco TAC, load a dplug and clean out the files for the concerned directories via dplug. Not sure if this was done. But a reboot will also clean out the files hence you did not see the issue after reload.
V.
