Upgrade from Ubuntu 11.10 to 12.04 problem
May 2nd, 2012
Hi all,
I was a happy Ubuntu 11.10 (64 bit) and Cisco Anyconnect 3.0.4235 user. But few days ago I have upgraded to Ubuntu 12.04 LTS. (Foolish - I admit) Now I can not connect to my work network anymore. Client just says: "Posture Assessment Failed: Hostscan Initialize Error." and does not make a connection.
I am able to connect to VPN service via web browser (I enter username and PIN+6digits into web form on our gateway) and disconnect the connection with Anyconnect client, but I can not make (establish) a connection with a client.
Thx!
Marcin Latosiewicz Wed, 05/02/2012 - 23:34
  • Cisco Employee,
Miro,
Looks like some problem with compatibility between CSD and this linux (kernel?) version.
Could you run a quick check against a profile which does not require CSD?
M.
mirokranjc Thu, 05/03/2012 - 02:15
Marcin, thank you for the reply.
I am not sure, but I think that by CSD you mean Cisco Secure Desktop, is this correct? What type of check against the profile that does not require CSD did you had in mind? I am ready to help if I can
Marcin Latosiewicz Thu, 05/03/2012 - 06:06
  • Cisco Employee,
Miro,
If you can, temporarily remove CSD on the tunnel-group you're connecting to.
It would look something like this:
tunnel-group AA_GROUP webvpn-attributes
without-cs
Try to connect when CSD is disabled.
I'm just guessing what you have configured , but best might be to open up  a TAC case, you'd get faster answer ;-)
M.
