Warning message
The ASA 5505 consumes 3 licenses if one host has access to the inside Network
May 2nd, 2012
I have one ASA 5505 version 8.2(1), the problem is when one host has access to the inside side from the outside side, the ASA consumes 3 licenses. So the ASA has 10 licenses but only 8 hosts can access simultaneously to the inside network.
Maykol Rojas Wed, 05/02/2012 - 19:49
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Ortiz,
Have you verified the Local-host output and check how many hosts appear there? If everything looks correct, you should try to update the code to 8.2.5, if the problem persist after checking the local-host and upgrading, contact Cisco TAC.
Mike
