Cisco ASA- ACS 4.2
Answered Question
May 2nd, 2012
I have cisco asa 5580 software 8.2, transparent, multicontext. i am trying to add the context to ACS 4.2.
i have added the device name and ip to ACS
and use the following commands on ASA
aaa-server ACSSRV protocol tacacs+
aaa-server ACSSRV (management) host x.x.x.x
key hello
aaa authentication serial console ACSSRV LOCAL
aaa authentication enable console ACSSRV LOCAL
aaa authentication ssh console ACSSRV LOCAL
aaa authentication http console ACSSRV LOCAL
ssh to device ask for username and password which i passed normally, type enable it ask for password.
i put the same password it wont work i used local password it is not working, what should i do ????
thankssssssssssssssssss
Overall Rating: 5 (1 ratings)
wimalathas nishan Sun, 05/06/2012 - 09:26
acs box check the fail log. If max session
Step 1 In the navigation bar, click Group Setup.
The Group Setup Select page opens.
Step 2 From the Group list, select a group, and then click Edit Settings.
The name of the group appears at the top of the Group Settings page.
Step 3 In the Max Sessions table, under Sessions available to group, select one of the following options:
•Unlimited—Allows this group an unlimited number of simultaneous sessions. (This action effectively disables Max Sessions.)
•n—Type the maximum number of simultaneous sessions to allow this group.
Step 4 In the lower portion of the Max Sessions table, under Sessions available to users of this group, select one of the following two options:
•Unlimited—Allows each individual in this group an unlimited number of simultaneous sessions. (This action effectively disables Max Sessions.)
•n—Type the maximum number of simultaneous sessions to allow each user in this group.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_ser...
alkabeer80 Sun, 05/06/2012 - 20:47
Hi nishan,
all of the config u mentioned is there, plz check below screenshot
i did debug aaa for ASA from console connection, i got "Restting 10.1.1.1 numtries" (10.1.1.1 is the IP of tacacs server)
maldehne Mon, 05/14/2012 - 00:09
  • Cisco Employee,
Under the user settings there is an option to specify against what to check the enable password
either using the same pap password defined for the user account or spearate one or another defined on external
database.
Check this link and let me know how it goes and what do you have:
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/UsrMgt.html#wp273989
If it is still  filing what is the reason for failure in the failed attempts
alkabeer80 Mon, 05/14/2012 - 03:28
thx for the reply, the URL is broken i can't access it
Related Content
