Cisco UCS C210 M2: PXE-E61:
May 3rd, 2012
I have bought two UCS C200 M2, when I switched on both server I' saw the following message PXE-E61Media test failure....
Together at UCS C210 M2 I received only the following licence VMW-UC-STD-K9-1A and UnityCN8-K9 and CD with Unity 8.
I tried to access at my VMware software (https://www.vmwaverestore/...........) but I Got the Access denied.
I tried to follow the procedure :
You will need to go into the LSI MegaRaid Controller Bios (Ctrl + H) and select the virtual
drives option on the left. When the Virtual Drives window opens, you must select the drive
(the Raid Volume) that you want as your primary boot disk and below there will be an option
to set as your boot device. Apply it and save.
But it seems that I have not set the drive - sample pic attached.
but at the end of the procedure I see always the same error:
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel Boot agent.
Reboot and Select proper Boot Device
My question are :
Is it normal to see the error PXE-E61: Media test failure, check cable ?
If Do I want the server working what I have to do ?
Thank you very much
Let me know
Best Regards
Carmine
Average Rating: 0 (0 ratings)
padramas Thu, 05/03/2012 - 02:49
Hello Carmine,
Issue #1 --  PXE-E61: Media test failure, check cable
What is the CIMC version and boot order for the server ?
If you have PXE in the boot order, remove it and let us know the outcome.
Issue #2 -- Registering VMware licenses
IFrom PID, ESXi software was bought via Cisco. Please check the following link for registration process.
http://docwiki.cisco.com/wiki/License_Activation_for_Cisco_UC_on_UCS
Issue #3  -- Boot drive
Yes, when you have mulitple RAID arrays ( Virtual drives ) , you can set the drive from which you have installed the OS and boot the server from.
You can enable the option
Padma
Login or Register to take actions
Posted May 3, 2012 at 1:18 AM
Stats:
Replies:1 Avg. Rating:
Views:1398 Votes:0
Shares:0
Tags: c210
Categories: General UCS Hardware
Related Content
Discussions Leaderboard
