UC540W Dial Plans
Answered Question
May 3rd, 2012
I'm going to purchase a UC device soon and would like to know if I can create/change manually dial plans on UC540W-FXO-K9?
I would like to customize it for Azerbaijan dialing rules.
Safar.
Correct Answer by paolo bevilacqua about 5 years 1 month ago
With manual configuration, you can do whatever you want.
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Thu, 05/03/2012 - 05:05
  • Hall of Fame,
    Founding Member
Thanks for the nice rating and good luck!
Correct Answer
paolo bevilacqua Thu, 05/03/2012 - 03:13
  • Hall of Fame,
    Founding Member
silvia.candela Mon, 08/20/2012 - 09:44
I´m from Perú and I´m about to purchase an UC540W, since there isn´t an specific dial plan for my country, I would like to know if I can modify one of the availables or I how to define a new one??
Safar Safarov Mon, 08/20/2012 - 10:07
Hi Silvia,
as far as I know you would be able to create a dial plan manually via CLI.
BR,
Safar.
johschaf Mon, 08/20/2012 - 15:30
  • Silver, 250 points or more
Hello All,
Dial plans can be customized in the UC500 series. This is also supported within CCA.
-john
Related Content
