Port Forwarding via SSH
dpatkins
I want to SSH into a Cisco 1841 router and depending on the suffix added to the SSH (i.e ssh myrouter.myroute.com 2002), would like it to forward this request to a terminal server.
Can this be done?  If so, how does one accomplish this?  I have done something similar with RDP but I was not sure about SSH.
Thank you
Dwane
John Blakley
Should be done the same way if your translating the port inbound. You can change the default ssh port on your 1841 with:
ip ssh port
Otherwise, you'll do your standard nat statements listening on the port that you want and then translating that port inbound:
ip nat inside source static tcp 192.168.1.20 22 5.5.5.5 2020
When you ssh into 5.5.5.5 2020 it will redirect to 192.168.1.20 on 22.
HTH,
John
HTH, John *** Please rate all useful posts ***
I know its thee year longs post, but if I want to achieve  i.e.ssh on 1.1.1.1 ip on port 22 through port translation to port 1000 but keeping ip same i.e 1.1.1.1 then how I would achieve it?
I have already done below mentioned thing.but no success.
ip nat inside source static tcp 1.1.1.1 22 1.1.1.1 1000
Parvesh Paliwal
Level 3
Level 3
Agree with blakley.
I will test this today.  Thank you all.  I have a question about SSH into an 1841.  How does this need to be configured if I would like to use a 3rd party certificate like a Comodo certificate?
