SSL VPN on a Cisco ASA 5505
May 3rd, 2012
I am attempting to configure an ASA 5505 with SSL VPN.  The users request is from anywhere, be able to web into the Cisco ASA. Https://myasa.here.com. At that point, we will require them to authenticate through Active Directory via ACS 5.2.  The Cisco ASA 5505 is a 50 user ASA.  We have also purchased the mobile license as well as a 10 user premium license.  That was a bear in itself.
My questions are:
1.  How do I configure the SSL setup to use a 3rd party certificate, such as a Comodo certificate?
2.  How do I determine which version of AnyConnect I should use for this?  We will support windows, macs, linux and smart phones as well as Tablets.
3. if you do a show version, you get all the capabilites of the ASA of which some are disabled or deactivated.  Does someone have a chart that will show us, what needs to be purchased to activated each line entry on the ASA?  Is there an all encompassing PAK?
Thank you all for your help.
Dwane
Mohammad Alhyari Tue, 05/08/2012 - 15:47
  • Bronze, 100 points or more
Mate ,
for your first question :
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808b3cff.shtml
a very useful doc:)
2- for anyconnect :
there is 2.5 and the 3.0 ( the new secure mobility client ):
release notes for the 2.5 client :
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect25/release/notes/anyconnect25rn.html
for the 3.0:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect30/release/notes/anyconnect30rn.html
the release notes contains a very useful information on the OS that we support .
3- you need to check feature you need to enable and then check the part number that you need to order , as far as i know there is no such chart .
hope that those will be useful:
Cisco Secure Remote Access: VPN Licensing Overview
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/overview_c78-527488.html
cheers.
Mohammad.
Related Content
