Nexus 5000/2000 connected to ESX host with 2 teamed NICS
Answered Question
May 3rd, 2012
I have a question regarding a configuration we have in our Datacenter (see above)
The issue is with the Server configuration on the switch (Please note this is an ESX host with 2 NICs (active/active, same vSwitch), 1 NIC each connected to a different FEX)
Currently we have removed the 'channel-group x' from under the individual ports on each FEX and have full connectivity, i.e. no vPC configuration, how can this be working?
Rgds
Jake
Correct Answer by Marcel Zehnder about 5 years 3 weeks ago
ESX uses per default the following NIC-teaming method:
"Route based on the originating port ID"  - Also know as vSwitch port-based load-balancing,  this method chooses an uplink based on the virtual port where the  traffic entered the virtual switch
(check out this PDF: http://www.vmware.com/files/pdf/virtual_networking_concepts.pdf)
With this method you don't need to configure a channel on your Nexus switches. If you configure a port-channel (vPC) you should reconfigure the ESX vSwitch teaming to "Route based on IP hash" and make sure your port-channels on the nexus are configured as static ports (mode on) because ESX is not able to do LACP.
Marcel
Overall Rating: 5 (1 ratings)
Correct Answer
Marcel Zehnder Thu, 05/03/2012 - 13:47
  • Bronze, 100 points or more
Marcel
Trending Topics: Other DC Subjects
