C1841 router vpn setup issue
May 3rd, 2012
I have issue with setting up c1841 router for vpn access. Below config is extracted from the running-config. Please also find attahed the debug log output.
crypto isakmp client configuration group vpn-group
key 128382671
dns 200.xx.xx.xxx
domain group.com
pool vpnpool
crypto ipsec security-association lifetime seconds 180
crypto ipsec transform-set myset ah-sha-hmac esp-des esp-md5-hmac
crypto ipsec transform-set yourset ah-md5-hmac esp-3des comp-lzs
crypto dynamic-map DYNMAP 10
set transform-set myset yourset
match address 101
reverse-route
crypto map CLIENTMAP local-address FastEthernet0/1
crypto map CLIENTMAP client authentication list AUTHEN-LIST
crypto map CLIENTMAP isakmp authorization list AUTHEN-LIST
crypto map CLIENTMAP client configuration address respond
crypto map CLIENTMAP 10 ipsec-isakmp dynamic DYNMAP
Best Regards,
Ruveni
Mohammad Alhyari Tue, 05/08/2012 - 15:22
  • Cisco Employee,
Hi Mate ,
a few comments if you don't mind :
1- did you confgure an isakmp policy with  DH group 2 .
2- why you are using an access-list under the dynamic crypto map .
is it possible to attach the full config of the router ? the debugs are showing that we are not going beyond IKE first message as the router refuses the proposals offered by the client .
hope that hsi helps .
Mohammad.
rwaqanitoga Tue, 05/08/2012 - 21:53
Hi Mate,
Am basically able to authenticate using cisco vpn client but does not indicate any connection.
Please find attached the running-config and the debug log...
Many Thanks,
Ruveni
