Warning message
CUEAC using G729 codec between regions
May 3rd, 2012
Does anyone know how I can get CUEAC 8.6.2.11 to use the G729 codec between regions? I’m deploying CUEAC to many remote sites who all use the G729 codec between regions. There is the issue of the calls dropping when being transferred or put on hold. I can get CUEAC to work with G711 between regions no problem. The release notes say that the new Cisco Media Driver can support the G729 codec when pass-through mode is enabled via the regedit??? Cannot find it! Alternatively, how can I get CUEAC to use the transcoders configured on my gateways? I need CUEAC to use G729. I have logged a TAC case but they seem to take a while.
Thanks in advanced
Marcus
Tim Smith Thu, 05/03/2012 - 15:33
  • Silver, 250 points or more
Do you have transcoders configured and registered with correct codecs available? Are transcoders available in CUEAC CTI port MRGLs?
Transcoder should be invoked automatically when the end points cant agree on codec.
Is the call through a gateway? I would test internally first then build on that.
Cheers,
Tim
marcusdewaal Fri, 05/04/2012 - 04:03
Hi Tim
I have the central and remote site hardware transcoders in the in the the CTI port device MRGL. The xcodes are registered in call manager and the correct codecs are installed? The call comes into the queue and answered but still drops on hold? I can see xcoder is still not being invoked when I do a show sccp connections on the gateways. The call goes across the WAN.
Marcus
