891w connecting to wlc 5508
May 3rd, 2012
I am having problems connecting an 891w to a WLC, is it possible to have to separate vlans, one for the Lan ports and another for the AP modue.
I do not want the AP part of the 891w in autonomous mode. The WAN port of the router will be connected to a DSL type service.
Is there a guide or something to get a 891W to connect to the WLC?
I would like to have users on a data vlan (vlan1) connecting to the network like a normal router, then the AP module to connect to the WLC via a different IP proablly vlan 2
On the WLC itself i do not see any attempts in the logging.
Leo Laohoo Fri, 05/04/2012 - 18:02
Describe your problem?
Can you post the output to the following command:
WLC:  sh sysinfo
WAP:  sh inventory
WAP:  sh version
890W:  sh version
CSCO10279398 Tue, 05/08/2012 - 15:07
WLC: sh sysinfo
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... SIGNRYCC01
System Location.................................. SIG NRY
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.192.22.10
Last Reset....................................... Software reset
System Up Time................................... 49 days 19 hrs 47 mins 11 secs
System Timezone Location......................... (GMT+10:00) Sydney, Melbourne, Canberra
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... AU  - Australia
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +28 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 2
Burned-in MAC Address............................ CC:EF:48:0C:7F:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 50
ap#sh inventory
NAME: "AP801", DESCR: "Cisco AP801 Access Point with dual IEEE 802.11a/g/n radio ports"
PID: AP801AGN-N-K9     , VID: V01, SN: FGL161721MR
ap#sh ver
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:59 by prod_rel_team
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(23c)JX, RELEASE SOFTWARE (fc1)
ap uptime is 11 minutes
System image file is "flash:/ap801-k9w7-mx.124-21a.JA1/ap801-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AP801AGN-N-K9        (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FGL161721MR
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:CA:9B:2A:F8:E8
Part Number                          : 73-11027-11
PCA Assembly Number                  : 800-28808-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC16122N66
Top Assembly Part Number             : 800-29576-05
Top Assembly Serial Number           : FGL161721MR
Top Revision Number                  : C0
Product/Model Number                 : AP801AGN-N-K9
Configuration register is 0xF
890W: sh version
Cisco 891 (MPC8300) processor (revision 1.0) with 393216K/131072K bytes of memory.
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Serial interface
2 terminal lines
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO891W-AGN-N-K9    FGL161721MR
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
CSCO10279398 Tue, 05/08/2012 - 15:10
Can i have two separate vlans, so one for the AP wireless and another for lets say data hosts connecting to the ethernet ports, it seems i can not separate the two, yes i can configure it but just does not seem to work as a layer three device, if i set it up as an AP (layer 2) fine it works, but if i try to configure as a router with an AP just does not connect to the wlc.
Leo Laohoo Tue, 05/08/2012 - 15:44
Mate, on your router, run this command "service-module wlan-ap 0 bootimage unified".  The WAP will boot into LWAP/CAPWAP image and hopefully your 5500 should be able to see the WAP.
Thomas Jennings Mon, 09/17/2012 - 16:52
Hello
Sounds like you suggestion allowed the 891 router with Wireless interface to join a 5508
I am looking at a similar design and had some questions
Is there a code version on the WLC required?
Does this 891 use a AP license?
Is HREAP mode required?
Do you know of any docs Cisco may have , can you send links if so ?
Is this a bridge solution?
Thanks , Tom
Leo Laohoo Thu, 09/20/2012 - 13:18
Yes.  Look it up in the Release Notes for the WLC.
Yes, one.
HREAP/FlexConnect is an option.
There are alot of Cisco documentations.  Which one do you like?  Wireless?  WLC?  Routers?  Which one?
Scott Fella Thu, 09/20/2012 - 16:25
You crack me up Leo
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Related Content
