05-04-2012 03:22 AM - edited 03-11-2019 04:02 PM
Since moving to the new object oriented nat syntax - i have encountered problems with using port address translation from many to many.
With many thousands of users behind a firewall all passing traffic from inside to outside, I am required to resort to using a pool of external IP addresses, so as not to run out of sockets.
Bit Torrent and other similar apps can cause a world of mess.
While I can configure port address translation as follows:
object network PRIMARY_OUT
range x.x.x.x x.x.x.x
object-group network INSIDE
network-object 0.0.0.0 0.0.0.0
nat (any,Primary) source static INSIDE PRIMARY_OUT
While this works there is a single glaring problem that I cannot overcome - irrespective of adding it to the fixup protocol inspection.
When PATing to multiple IP addresses on the outside, PPTP VPNs cease to work.
The only way to overcome this is to PAT to a single overloaded IP address or interface.
Am I doing something wrong? This all worked fine with the old school nat (inside) global (outside) style configuration.
Any help or tips would be warmly received.
05-04-2012 03:47 AM
You might try to exempt the VPN from being nat-ed
object-group network VPN
network-object x.x.x.x x.x.x.x
nat (inside,outside) 1 source static INSIDE INSIDE destination static VPN VPN
Dan
05-04-2012 04:01 AM
I might be being dim, and I also might have failed to relay my question correctly.
The problem is with users behind the firewall - who are NAT'd getting out the internet, who require to use a PPTP VPN to remote sites beyond our firewalls.
Would your recommendation overcome this issue?
Many thanks.
05-04-2012 07:45 AM
The only way to overcome this might be to carve out some addresses from that NAT range and set up statics for those internal users who require PPTP outbound access.
Check the xlate table and see if the PPTP users are opening multiple sockets when connecting to their VPN peers.
05-05-2012 01:54 AM
Thanks Colin, unfortunately I don't think that this is going to be a scalable solution given the nature of the network and userbase.
Is a PAT pool singularly incompatible with PPTP passthrough because of the dynamic nature of source/dest port allocation? Also why is this possible when overloading to a single IP address, rather than a pool?
Many thanks for your help.
