Cisco WLC 4404/5508 Web Authentication by AD Security Groups
Answered Question
May 4th, 2012
Hey
I'm searching for a solution to web authenticate users within a specific Active Directory Security Group. I tried to authenticate over Radius with Cisco Secure ACS and Network Access Restrictions. But NAR only works with Layer 2 authentication. And Web Authentication over LDAP can only be used with User Objects.
Any ideas?
best regards,
Marc
Correct Answer by Amjad Abdullah about 4 years 11 months ago
Scott:
You and maldehne are saying the correct thing. However, this is some kind of limitation that cisco should improve in the future. classifying users based on groups in AD is more flexible than classifying based on OU's when using LDAP. If there is anything that can be implemented to classify users based on AD groups at Layer 3 auth level that will be very useful functionality for cisco products.
Overall Rating: 5 (1 ratings)
Scott Fella Sat, 05/05/2012 - 08:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Are you trying to authenticate Administers of the WLC's to AD or are you trying to use WebAuthentication allowing access to the Security Group?  If you are trying to use ACS to allow for Administers to have access to the WLC's then you would use ACS TACACS not radius.  You would need role1=ALL as a shell profile for that policy and point to your Security Group in AD.
Do a search for role1=ALL on this forum and you will get many hits.
Marc Aemmer Sat, 05/05/2012 - 09:28
No, i want to control access over web authentication with AD Security Groups. With web authentication over LDAP, I cannot define security groups, only OU's.
Scott Fella Sat, 05/05/2012 - 09:35
  • Hall of Fame,
    2017 Wireless
That is the same with IAS/NPS also, you have to point to an OU. I was thinking you specified a Security Group OU. The only workaround is to put the Security Group users in a new OU that radius can be pointed to.
Scott Fella
Sent from my iPhone
Correct Answer
Amjad Abdullah Sat, 05/12/2012 - 22:33
  • Blue, 1500 points or more
Scott:
maldehne Sat, 05/12/2012 - 20:36
  • Cisco Employee,
Have those users only under certain container on your LDAP server and  use its DN as the user Base DN to be defined on the controller , thus  restricting the search for that branch of the LDAP Tree.
Trending Topics - Security & Network
