Catalyst 3560 V2
Answered Question
So, We've just received two new catalyst 3560V2 switches and either I've lost my mind or the IOS has had some changes...
Line VTY 0 4
     Login Local
command does not work.  So, I downloaded a new IOS
c3560-ipservicesk9-tar.150-1.SE2
and still no luck...
Have I lost it or does the IOS no longer support it?
Here is currect Console and VTY lines running on a different 3560 switch...
line con 0
privilege level 15
password 7 152B29025438262524
login local
line vty 0 4
access-class 99 in
privilege level 15
login local
line vty 5 15
access-class 99 in
privilege level 15
password 7 012A240A0B190B0E2D
login local
Correct Answer by siddhartham about 5 years 3 months ago
its most likely the aaa new-model config
Overall Rating: 5 (1 ratings)
Nandan Mathure Fri, 05/04/2012 - 10:18
  • Bronze, 100 points or more
Do you have "aaa new-model" configured? that might be causing it or check if local username password needs to be created first etc.
Nandan Mathure
Correct Answer
siddhartham Fri, 05/04/2012 - 11:18
  • Silver, 250 points or more
Related Content
