question about nat on asa v8.0 with same-security interfaces
May 4th, 2012
I want to make sure I understand how the nat requirements work on asa v8.0 when inter-interface is set.  Background:
nat control is off.
same-security-traffic permit inter-interface is on.
"inside" and "MPLS" interfaces are both at security level 100.
"outside" is, of course, as security level 0.
The relevant config looks like this:
interface Ethernet0/0
nameif outside
security-level 0
ip address <public IP>
interface Ethernet0/1
no nameif
security-level 100
no ip address
interface Ethernet0/1.10
vlan 10
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Ethernet0/1.20
vlan 20
nameif MPLS
security-level 100
ip address 192.168.3.1 255.255.255.0
access-list inside_nat0_outbound extended permit ip any Net-192.168.105.0 255.255.255.0
access-list MPLS_nat0_outbound extended permit ip any Net-192.168.0.105 255.255.255.0
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound_1
nat (inside) 101 Net-192.168.0.0 255.255.0.0
nat (MPLS) 0 access-list MPLS_nat0_outbound
nat (MPLS) 101 Net-192.168.0.0 255.255.0.0
static (MPLS,outside) <public IP> <MPLS internal IP> netmask 255.255.255.255
static (inside,outside) <public IP> <inside internal IP> netmask 255.255.255.255
Am I correct in thinking that traffic will pass between inside (192.168.2.x)  and MPLS (192.168.3.x) in either direction with NO natting, assuming the access-groups assigned to the interfaces permit the traffic?
-Mathew
Maykol Rojas Fri, 05/04/2012 - 10:12
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Matt,
Nope, because in your Nat0 is not defined for those two networks, they will end up hitting the egular NAT inside that actually covers it and it will say no translation group found.
Mike
mat_rouch Fri, 05/04/2012 - 11:10
I had been under the impression that if there was no nat or static that matched it woul permit the traffic with no natting.
If I add one line:
access-list MPLS_nat0_outbound extended permit ip Net-192.168.0.0 255.255.0.0 Net-192.168.0.0 255.255.0.0
Should it work for traffic originating from either inside or MPLS?  Based on my packet-tracer output it appears that it should.
-Mathew
Maykol Rojas Fri, 05/04/2012 - 13:55
  • Cisco Employee,
Matt,
You are Totally right, however this Nat rule
Is a /16 Which will take 192.168.3.0, will use that NAT and then try to find a global for it. Now, If you add that ACL as part of your NAT0 configuration, that will do the trick.
Mike.
