CUC Locale
May 4th, 2012
  • Blue, 1500 points or more
I installed the CUC Locale Portuguese BR but i not able to change the default system language on System Settings -> System Default Language.
I not upload the license yet this could be the reason?
Overall Rating: 5 (3 ratings)
Luis Gustavo Al... Fri, 05/04/2012 - 14:18
What version of CUC are run running and do you see the new install language available in the drop down?
-Luis
Chris Deren Fri, 05/04/2012 - 18:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, you do not need license in order to do this. Did it install correctly, do you see it as available language when you go for example to define user template?
What exact version of CUC are you running and what version Locate did you install?
Chris
Leonardo Tadeu Fri, 05/04/2012 - 19:06
Ok, yes i install in OS Admin, after that i reboot the server and the locale did not appear.
CUC Version 8.6.2
I download the last version of the locale for CU:
uc-locale-pt_BR-8.6.2.1-25.cop.sgn
Rob Huffman Sat, 05/05/2012 - 09:53
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Leonardo,
I really think that Luis may be onto something here + 5 "L"
There are different 8.6.2 locales depending on the exact version
of Unity Connection you are running;
Installing Additional Cisco Unity Connection Languages
Revised April 25, 2012
NoteAll locales other than ENU are released for Connection 8.6(2) Engineering Special 12. Connection 8.6(2) ES 12 locales are supported only with Connection 8.6(2) ES 12.
All locales other than ENU are released for Connection 8.6(2) SU 1 (ES 25). For more information on the supported engineering-special versions with these locales, please contact Cisco Technical Assistance Center (TAC).
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/862cucrn.html#wp1300703
You may want to try this version instead;
Cisco Unity Connection Locale Installer 8.6(2) ES12 - Brazilian Portuguese
uc-locale-pt_BR-8.6.2.1-12.cop.sgn
Cheers!
Rob
"Everything is broken" - Bob Dylan
Rob Huffman Sat, 05/05/2012 - 10:16
  • Hall of Fame,
    Founding Member
Hi Leonardo,
Could be this bug as well;
CSCtt21815 Bug Details Bug #4 of 56 | < Previous | Next >
CUC 8.6 Locale is not listed in the admin webpage.
Symptom:
Locale is not listed in the admin webpage after installation.
Conditions:
Unity Connection 8.6 after a refresh upgrade, the issue can occur with any non-ENU locale.
From the CLI "show cuc locales" lists the locale as installed, but it is not listed in the admin webpage, so the installed locale cannot be configured.
Workaround:
This workaround requires root access - please contact TAC
StatusStatus
Fixed
Severity Severity
2 - severe
Last Modified Last Modified
In Last month
Product Product
Technology Technology
1st Found-In 1st Found-in
8.6(1)ES3
Fixed-In Fixed-in
9.0(0.96000.25)
9.0(0.96000.26)
9.0(0.94)
8.6(2)ES19
8.6(2.21013.1)
9.0(0.96000.267)
9.0(0.96000.310)
Cheers!
Rob
Leonardo Tadeu Sat, 05/05/2012 - 12:49
I made an upgrade from CUC 8.0 to CUC 8.6.2 and after i installed the locale, is not listed!
I will try to remove and install again if not work i will open a case on Cisco TAC.
Thanks!
Related Content
