Nandan Mathure Sat, 05/05/2012 - 04:16
Hi!
So understand this better, could you share the configuration along with few more details?
Nandan Mathure
fb_webuser Sat, 05/05/2012 - 08:32
yeah sure the config
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ipv6 unicast-routing
ipv6 cef
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address 2001:500:500:500::254/64
ipv6 enable
ipv6 policy route-map ipv6
interface FastEthernet0/1
no ip address
duplex auto
speed auto
ipv6 address 2001:600:600:600::254/64
ipv6 enable
ipv6 nd ra suppress
interface FastEthernet1/0
no ip address
duplex auto
speed auto
ipv6 address 2001:700:700:700::254/64
ipv6 enable
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 101 permit tcp any any eq www
route-map ipv6 permit 10
match ipv6 address ipv6
set ipv6 next-hop 2001:600:600:600::1
ipv6 access-list ipv6
permit ipv6 2001:500:500:500::/64 any
so you can see that basically i need to redirect certain traffic to ip next hop the thing is that when traffic start to flow the ipv6 neighbour table start to fill up with ipv6 neighbours and then the router pass the traffic directly through itself and not to the next hop ip as ip configure on the route map
10X for the help
Posted by WebUser Yehonatan Shemesh from Cisco Support Community App
