Warning message
CCX 7.0
Answered Question
May 4th, 2012
Is anyone still using ccx7.0 if so how was the install difficult,easy ?   Recommendations any advise would be helpful
Correct Answer by Chris Deren about 5 years 3 months ago
Is there a reason you need to install UCCX 7?  Remember it is EOL, and most recent version is 8.5.1SU3.   Also, 7.0 is Windows based as oppose to appliance, so if the ultimate plan is to upgrade to newer version you will need to rebuild the server completely. (Database configuration can be restored via PUT tool).
HTH,
Chris
Correct Answer by amatine about 5 years 3 months ago
Correct Answer by anchoudh about 5 years 3 months ago
Its pretty easy, you need to have the supported hardware, install the supported OS, install SQL (provided with UCCX only) and run the installer of UCCX.
Please refer the below comp matrix for hardware\OS...etc
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Also refer the below UCCX 7.0 install guide for stet by step guidance.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/installation/guide/uccx70ig.pdf
Note:
1. Keep the UCCX 7.x license
2. CUCM\CUCME shold be available for integration.
Hope it helps.
Anand
Please rate helpful posts !!
Overall Rating: 5 (3 ratings)
Correct Answer
anchoudh Sat, 05/05/2012 - 00:40
  • Red, 2250 points or more
Note:
Hope it helps.
Anand
mel.farhat Sat, 05/05/2012 - 09:04
Thanks to those who replied, very helpful and appreciate your advise
Correct Answer
amatine Sat, 05/05/2012 - 00:51
  • Cisco Employee,
Correct Answer
Chris Deren Sat, 05/05/2012 - 07:02
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
mel.farhat Sat, 05/05/2012 - 09:11
Your right, we have the hardware and the software. We just wanted to get our feet wet with 7.0. Our help desk just increased from one person to four. It may not be a success due to the hardware being older, the end result may be what you suggested. Thanks Chris
