configuring a Cisco 3750-x port for multi vlan
nyasham14
Scenario: I have a vmserver w four virtual servers all in configured w in different subnets. What's the best way to configure a 3750-x switch to route traffic from the virtual servers to their vlans?
Mehdidz
I think that you will have to provide more information regarding the server itself  for now what would be abvious is if your server NIC support trunking than you need to configure the switch port to trunk
Mehdi
Reza Sharifi
If you are using the 3750 as a layer 3 device then you need to creat an SVI for each subnet
If the 3750 is a layer 2 device than you can bundle all your links using an Etherchannel using LACP
