double authentication pain: asa webVPN access and browse networks
Answered Question
May 5th, 2012
I'm configuring an asa device for web access: SSL VPN service. I can have a user authenticate for web session with their active directory domain credentials (username and password). Once their web session has started, moving to the "browse networks" feature for a share viewing requires them to authenticate once again - "authenitcation required". I'd like to configure the device so that authenticating to the windows file share will be attempted using the previously entered credentials.
How might I accomplish this if it is this possible?
This is an ASA5510 with sw 8.4(3).
thanks
John
Correct Answer by Marcin Latosiewicz about 4 years 10 months ago
John,
Start here:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/vpn_clientless_ssl.html#wp2281498
Auto signon or single signon is the typical phrasing.
M.
Overall Rating: 5 (1 ratings)
srlguy Mon, 05/07/2012 - 11:48
Thank you Marcin. That was helpful. I did have a friend named google but getting the terms matching the documents you seek is easier once you've found it once.  I find it takes some time to assemble the collection that applies to any given situation.
thanks
John
Related Content
