Cisco 2950 does it have DHCP Server?
djelizondo
I googled this and couldnt get a clear answer. I was reading it supports DHCP relay? im assuming its just relaying dhcp from the router.
I am wondering if it has its own DHCP router and if theres a command to enable it?
Also Random side question. it hands out ip addresses to other devices (the 2950 im using infront of a router) but when I hook up another switch to this switch it doesnt initialize the port or try to connect? why.
Peter Paluch
Yes, the 2950 does support a DHCP Server and/or DHCP Relay functionality. However, it is strongly limited: on these platforms, there can be at most one SVI in the no shutdown state. That means that a 2950 can provide DHCP Server or Relay services only to a single directly-connected VLAN.
There was a similar issue discussed here:
https://supportforums.cisco.com/message/3530571#3530571
It is not common to run a DHCP Server or a Relay service on a switch, anyway. Do you need it?
I do not quite understand this description. However, you may need to use a cross-over cable, as 2950 do not have the auto-cross (auto-MDIX) functionality.
Best regards,
Peter
