failover configuration query
May 5th, 2012
hi ,
I have a cisco asa 5510 with security plus license in Live enviroment .
I need to add a secondary firewall .
I was planning to do in active /standby mode for failover .
But i have a doubt , when i do "show version " on live asa output says Active /active failover , does this means that i can only configure failover in active/active mode not in active/standby (which i want to do )?
please advice
sh ver
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 20, DMZ Unrestricted
Inside Hosts                 : Unlimited
Failover                   : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
VPN Peers                    : 25
WebVPN Peers                 : 2
Dual ISPs                    : Enabled
VLAN Trunk Ports             : 8
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has an ASA 5505 Security Plus license.
varrao Sat, 05/05/2012 - 14:02
  • Red, 2250 points or more
If you have active/active license, you can configure active/standby as well, but if you only have active/standby then you cannot configure active/active failover.
Varun
Mohamed Sobair Sat, 05/05/2012 - 14:03
  • Gold, 750 points or more
This is means it supports Active/Active Failover as well, So your Firewall now supports both Active/Standby and Active/Active Failover configuration.
Mohamed
amit bhatnagar Sat, 05/05/2012 - 14:12
thanks varun / mohammad for confirmation
how will i know in already exiting firewall in failover that it is active/active or acctive /standby ?
regards
amit
varrao Sat, 05/05/2012 - 14:25
Hi Amit,
active/active failover is done by creating contexts, you can check it by:
show failover
this output would show you if it is active/standby or active/active.
Read through this configuration docs as well, it would help:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml?referring_site=smartnavRD
Hope that helps,
Varun
