Connect a 3560G to a linksys E4200
May 5th, 2012
Hi all,
I'm a bit new to Cisco, it's been 7 years ago that I passed my CCNA. I'm setting up a new network at my home and can't get it working.
I have a Linksys E4200 that is connected to the internet.
I have a Cisco 3560G-48TS for my virtualisation project.
On this 3560 I have made some VLAN's for the vSphere environment, when I make a trunk to the dvSwitch I can ping the default gateway and the other hosts on the same VLAN but can't connect to the internet.
Port Gi0/3 is connected to the E4200, now I have internet on all PC's in VLAN1. If I switch the cable to port Gi0/1 the internet connection is gone for all PC's.
Also I can't reach the switch by IP 192.168.1.2.
I hope somebody can help.
See the running config attached.
Some extra info:
IP-address of the E4200: 192.168.1.1
IP-address of Gi0/1: 192.168.1.2
Thanks!
Average Rating: 0 (0 ratings)
Reza Sharifi Sat, 05/05/2012 - 14:17
Since you are using vlan 1 with g0/3 interface and everything works fine can you make sure g0/1 is also in vlan 1?
By default all ports are in vlan 1 until you put them in a different vlan
chenoufimehdi Sat, 05/05/2012 - 14:19
I'd move the g0/1 config to vlan 1 inteface
( are you using DHCP for the subnets other than 192.168.1.x?  for vlan 1 I guess that the  E4200 is the server ?
if you are using static IP assignement make sure to have the correct default gateway which is the correspending SVI ?
regards
Mehdi
martgombert Sat, 05/05/2012 - 14:34
I didn't change the VLAN of port g0/1. I now changed VLAN1 to this:
interface Vlan1
description Link naar E4200 (router)
ip address 192.168.1.2 255.255.255.0
And maked g0/1 default. Still no internet on the other VLAN's.
I use the E4200 for DHCP on 192.168.1.x and wanna use my Synology for DHCP on the other subnets, but thats for later...
Reza Sharifi Sat, 05/05/2012 - 14:44
Can you post the output of
Sh ip int bri vla1?
Also
Sh ip int bri gi0/1?
martgombert Sat, 05/05/2012 - 14:50
Switch#Sh ip int bri vla1
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.1.2     YES manual up                    up
Switch#Sh ip int bri gi0/1
GigabitEthernet0/1     unassigned      YES unset  down                  down
chenoufimehdi Sat, 05/05/2012 - 15:07
can you do a traceroute to let's say 8.8.8.8 from one of the pc in other vlans ?
martgombert Sun, 05/06/2012 - 01:53
From a Windows XP client behind the dvSwitch (attached to port g0/34) in VLAN130:
c:\> tracert 8.8.8.8
Bezig met het traceren van de route naar 8.8.8.8 via maximaal 30 hops
1 2 ms 2 ms 2 ms 192.168.130.1
2 * * * Time-out bij opdracht.
Reza Sharifi Sat, 05/05/2012 - 17:14
How come port 0/1 is down? Is anything connected to this port?
Died the port go to up and up mode when you connect it to the linksys?
pjmonline Sat, 05/05/2012 - 20:55
You could try to give the switch port connected to the 4200 an ip address in the same subnet and no switchport command. This would make the port a routed port then try the Internet again.
martgombert Sat, 05/05/2012 - 21:38
That's how I started, but it dont work. If I make it no switchport and give it an IP address also the computers in VLAN1 dont have access to the internet.
pjmonline Sun, 05/06/2012 - 06:36
I think the others are correct. You need a static router on the linksys router back I the other subnets/vlans.
Login to the linksys and define the routes for the other vlans and the gateway is the vlan1 management ip of the switch.
go.michael Mon, 05/07/2012 - 06:12
I believe your Router is just not capable of handling multiple VLANs.  Once you set the IP of the router to 192.168.1.1/24, it is only aware of that network.  Plus it will only NAT IPs that are on 192.168.1.0/24.  If you want to complete that lab you can get a Cisco ASA5505 which can handle trunking with your switch or even trunk it with your ESX Vswitch.
Login or Register to take actions
Posted May 5, 2012 at 1:43 PM
Stats:
Replies:14 Avg. Rating:
Views:1261 Votes:0
Shares:0
Discussions Leaderboard
Rank Username Points
1 16,069
2 9,198
3 8,197
4 7,552
5 7,538
