Warning message
Cannot Ping or Telnet through ASA
May 6th, 2012
Hi Experts,
I built the network like attached diagram, and hoping it to work like this:
the traffic coming from outside, which is VLAN 1, will pass through ASA and go to VLAN 100 and 254.Routing protocol between R0, ASA and R1 is OSPF.
The problem now is that, router R1 can already see all the route information but cannot ping/telnet to R0 or internet. I tried with acl but it doesn't work. Kindly please have a look with the configs below:
R0:
R0#sh run
Building configuration...
Current configuration : 2752 bytes
version 12.4
hostname R0
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.1.1 10.1.1.100
ip dhcp pool frankfurt
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
no ip domain lookup
vpdn enable
vpdn-group 1
archive
log config
  hidekeys
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.252
ip nat outside
interface FastEthernet0/1
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
router ospf 1
log-adjacency-changes
network 10.1.1.0 0.0.0.255 area 0
default-information originate
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.1.1.0 0.0.0.255
snmp-server community public RO
control-plane
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
R1:
R1#sh run
Current configuration : 1161 bytes
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 10.248.100.2 255.255.255.0
interface FastEthernet0/1.254
encapsulation dot1Q 254
ip address 10.248.254.2 255.255.255.0
router ospf 1
network 10.248.100.0 0.0.0.255 area 0
network 10.248.254.0 0.0.0.255 area 0
no ip http server
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.248.254.1 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 4 subnets
O       10.1.1.0 [110/11] via 10.248.254.1, 00:25:35, FastEthernet0/1.254
                 [110/11] via 10.248.100.1, 00:25:35, FastEthernet0/1.100
C       10.248.254.0 is directly connected, FastEthernet0/1.254
C       10.248.100.0 is directly connected, FastEthernet0/1.100
O*E2 0.0.0.0/0 [110/1] via 10.248.254.1, 00:25:35, FastEthernet0/1.254
               [110/1] via 10.248.100.1, 00:25:35, FastEthernet0/1.100
ASA:
ASA# sh run
: Saved
ASA Version 8.4(2)
hostname ASA
interface GigabitEthernet0/0
nameif outside
security-level 100
ip address 10.1.1.2 255.255.255.0
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.100
vlan 100
nameif inside
security-level 100
ip address 10.248.100.1 255.255.255.0
interface GigabitEthernet0/1.254
vlan 254
nameif inside_Tra
security-level 100
ip address 10.248.254.1 255.255.255.0
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list acl_out extended permit icmp any any
access-list acl_out extended permit tcp any any
access-list acl_out extended permit icmp any any echo-reply
access-list acl_out extended permit icmp any any time-exceeded
access-list acl_out extended permit icmp any any unreachable
access-list acl_out extended permit ospf any any
access-list acl_out extended permit ip any any
access-list acl_out extended permit icmp any host 10.1.1.1
access-list acl_out extended permit udp any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu inside_Tra 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group acl_out in interface outside
access-group acl_out in interface inside
access-group acl_out global
router ospf 1
network 10.1.1.0 255.255.255.0 area 0
network 10.248.100.0 255.255.255.0 area 0
network 10.248.254.0 255.255.255.0 area 0
log-adj-changes
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
telnet 0.0.0.0 0.0.0.0 outside
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username cisco password 3USUcOPFUiMCO4Jk encrypted
class-map inspection_default
match default-inspection-traffic
class-map default
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:a480e144892c65ff1e853becaffc26e9
: end
Maykol Rojas Sun, 05/06/2012 - 19:14
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Angran,
I guess the problem is that R0 does not know where Vlan254 is located. Can you try on Router 0
Ip route 10.248.254.0 255.255.255.0 10.1.1.2
Let me know.
Mike
Related Content
