Catalyst 6500 supervisor problem.
May 7th, 2012
Hi dears.
it have 2 Supervisor Engine 32 8GE.  one of it at locate at slot 5 and one of it locate slot 6.
At first time when i turn on the catalyst 6500.the slot 6 supervisor loaded normal and all of them are perfect l. when i write show module at this supervisor:(slot 6)
1   16 SFM-capable 16 port 1000mb GBIC       WS-X6516A-GBIC     SAL1304H5JP
2   48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1252E9K0
3   16 SFM-capable 16 port 1000mb GBIC       WS-X6516A-GBIC     SAL1304H5K8
4   48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1253EX80
9 Supervisor Engine 32 8GE (Other)       WS-SUP32-GE-3B     SAL1303GB8U
6   9 Supervisor Engine 32 8GE (Active)     WS-SUP32-GE-3B     SAL1303GB8U
Mod MAC addresses                       Hw   Fw           Sw           Status
1 0024.97cf.d528 to 0024.97cf.d537   4.6   7.2(1)       8.7(0.22)BUB Ok
2 0024.14d9.74f8 to 0024.14d9.7527 11.3   7.2(1)       8.7(0.22)BUB Ok
3 0024.97cf.d4c8 to 0024.97cf.d4d7   4.6   7.2(1)       8.7(0.22)BUB Ok
4 0024.976f.b7f0 to 0024.976f.b81f 11.3   7.2(1)       8.7(0.22)BUB Ok
5 0022.5589.12b2 to 0022.5589.12bd   4.6   Unknown     Unknown     Other
6 0022.5589.12b2 to 0022.5589.12bd   4.6   12.2(18r)SX2 12.2(33)SXH4 Ok
Mod Sub-Module                Model             Serial       Hw     Status
6 Policy Feature Card 3       WS-F6K-PFC3B       SAL1303GL2X 2.4   Ok
6 Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A     SAL1302G1ZT 4.0   Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Not Applicable
6 Passsee the er supervisor which is located slot 5. i
when i go slot 5 supervisor it is state on rommon mode.
i turn off catalyst and remove supervisor from slot 6(which is working nomal) and trun on again.
this is output at slot 5 supervisor.
Cisco IOS Software, s3223_sp Software (s3223_sp-IPBASE-M), Version 12.2(33)SXH4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 10-Nov-08 00:29 by prod_rel_team
Image text-base: 0x40231348, data-base: 0x41B58F70
MAC based EOBC installed
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
00:00:08: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 08-Oct-08 13:06 by integ Build [100]
00:00:08: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Cat6k-MSFC2A platform with 524288 Kbytes of ma
i do not know what is a problem and how i solve this issue at slot 5 supervisor.
please help me.
srereddy Mon, 05/07/2012 - 06:03
How did you end up in this issue? Was there any upgrade or any sort of operations executed on the module before the issue?
Anyways, Can you go to failed Sup which is in 'rommon' mode and enter "priv" command in to get into privilege mode and try to issue erase command to the whole NVRAM?
teymur azimov Mon, 05/07/2012 - 11:51
thank you to reply me. please consider that when i turn on  catalyst first time this issue occurs at slot 5 supervisor.
why this problem occurs at first time turning? what do you think that?
ok i do your config and then write you result.
Leo Laohoo Mon, 05/07/2012 - 15:32
Just as the log message said, the NVRAM is corrupted and couldn't read the IOS.  You need to copy the IOS from the supervisor card in Slot 6 onto a CF (this is by far the fastest method) and inserting this CF into the card in slot 5.  Console into the slot 5 supervisor card and force this card to boot from CF.
teymur azimov Mon, 05/07/2012 - 22:23
Dear Leolaohoo
The image file in the CF at both supervisors is identical. As I know, IOS image is located at CF, and how IOS booting is related to NVRAM corruption?
P.S. That switch wasn't powered up for 4 years (it was ordered 4 years ago and only now powered up)
thanks
