Should I config both cos-map and dscp-map for output queue
May 7th, 2012
Dears,
I am wondering if I need config both cos-map and dscp-map for output queue, I have added the cos-map cmd as following:
SW(config)#mls qos srr−queue output cos−map queue 1 threshold 1 5
should I config also:
SW(config)#mls qos srr−queue output dscp−map queue 1 threshold 1 40 41 42 43 44 45 46 47
or the dscp-map will generate automatically?
Qilin
Sergey Fer Mon, 05/07/2012 - 07:36
  • Bronze, 100 points or more
No, DSCP-output-q map will not change. But if you trust CoS you may change your DSCP using cos-dcp map.
