AIR-AP3502i gigabit interface issue
May 7th, 2012
Support Community,
          I currently have an issue with my AIR-AP3502i gigabit interface. I connect my AIR-AP3502i to my 3560G POE switch and the port will not negotiate to1GB. I have tried auto negotiate and hard coded settings but when I try those settings the switch and AP interfaces go into an up down state. Has anyone seen this issue before?
Overall Rating: 5 (1 ratings)
shh5455 Mon, 05/07/2012 - 13:51
That sounds like a cable problem to me.  Plug the AP directly into the switch with a new cable and see if it is still an issue.
Edwin Carrasquillo Mon, 05/07/2012 - 21:10
Tried a different cable and different port switch, still same issue, it only negotiates at 100MB full.
Leo Laohoo Mon, 05/07/2012 - 15:18
I've seen and heard of this sob story before.
This is most likely caused by a faulty cable or the cable run, particularly the pair that supports 1 Gbps (fourth pair).  One way to isolate and determine if this is the case is to run a TDR
The good part is you have a 3560G so this appliance will support TDR.  Here are the command combinations:
1.  Command:  test cable tdr interface ;
2.  Wait for about 7 to 10 seconds (3560 takes longer than a 2960/3750);
3.  Command:  sh cable tdr interface ;  and
4.  Kindly post the output.
Leo Laohoo Mon, 05/07/2012 - 21:19
My IOS appears to not have that command option. Is that in a specific switch IOS version.
Can you please post the full output to the command "sh version" please?
Edwin Carrasquillo Mon, 05/07/2012 - 21:50
Never mind, I was mistaken, the command was there. Thanks for the new command.
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/7     100M  Pair A     0    +/- 4  meters Pair A      Normal
                Pair B     132  +/- 4  meters Pair B      Fail
                Pair C     110  +/- 4  meters Pair C      Fail
                Pair D     1    +/- 4  meters Pair D      Normal
Leo Laohoo Mon, 05/07/2012 - 22:38
Please forgive me for this comment:  WTF!  Wow!  That's one lousy TDR result.
Edwin Carrasquillo Tue, 05/08/2012 - 07:03
It is only a patch cable and not an actual cable run. As yo ucan see in a previous reply. I tried another patch cable and a different switch port.
Leo Laohoo Tue, 05/08/2012 - 16:21
Please test the entire run (from the switch to the WAP).
The two results you've posted are the same but as I can see this it won't work.  Pair C controls the PoE.  Pair B controls OSI Layer 2.
It's also telling me that the switchport is detecting Pair D (controls GigabitEthernet) at only 1 metre.
Moral Lesson:  The output is showing me that your cable directly connected to the switchport is manually spliced-n-diced (not machine manufactured) and someone did a poor job at it.
Edwin Carrasquillo Wed, 05/09/2012 - 06:50
The issue was the patch cable, however these were not man made patch cables. These must have been a bad batch of cables.
Thanks for your help and the new command to use.
Leo Laohoo Wed, 05/09/2012 - 15:57
Cool!  Glad to see it's working.
Leo Laohoo Mon, 05/07/2012 - 22:37
Thanks Blake.
Just want to remind you that I would not recommend using TDR on a Catalyst 4500 or 6500.  Works very well if you have 2960/2960G/2960S, 3560G/3560E/3560X and 3750G/3750E/3750X.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
