Xlite connect to CME behind NAT
May 7th, 2012
When Xlite is in the same network with CME the registration works fine. When I try to connect Xlite outside the network I receive 408 - Request Timeout. The CME is behind NAT so I configure port forward - public 5060 to CME 5060 port, but the same result. With the same port forward configurations and non-Cisco gateway the registration works fine.
Are there any other configurations for CME in order to register Xlite from outside the network?
Ty
Dennis Mink Mon, 05/07/2012 - 17:02
  • Gold, 750 points or more
please provide us with the make and model of you FW as well as config.   did you run wireshark at all on your xlite machine?   what sort of other diagnostics have you performed?
Mahmoud Abdelaal Mon, 02/11/2013 - 14:12
i have the same issue except i didn't try with non-cisco gateway
my CME is behind NAT and i need to register x-lite on it from outside network, i have no problem when i tried to register from inside
here is my config
[code]
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 192.168.1.2 port 5060
max-dn 2
max-pool 2
authenticate register
tftp-path flash:
create profile
voice register dn  1
number 1001
allow watch
voice register pool  1
id mac 0000.0000.1001
number 1 dn 1
username 1001 password cisco
codec g711ulaw
[/code]
Related Content
