Rv220W does not auto-update dyndns
May 7th, 2012
I am trying to have the RV220W router auto-update the dyndns registration.
The dynamic domain that I use is .info -- note the .info domain.
When I manually update the dyndns information (username and password) the registration does go through and the entry is updated on the dyndns site.
However, the registration does not auto-update after that.
Any ideas why this might be happening?
Alex
I believe this is a known issue.  You might perform a search.  At any rate, I'd call Tech Support and open a ticket.  The more information you have to offer, the better chance they have to reproduce the issue so it can get resolved.  It also seems as though the bugs that are bugging (pun intended) folks the most get the most attention.
Jason L Thu, 07/05/2012 - 07:50
I have the same problem on the RV220W with a .org domain from DynDNS, using the latest firmware, 1.0.3.5.  It will update manually, and on a reboot of the router, but does not update automatically.  I've tried several setting or the update persiod, and it did not make a difference.  Is there any word on a fix for this?
Te-Kai Liu Thu, 07/05/2012 - 12:23
  • Gold, 750 points or more
The DDNS auto-update issue has been fixed with firmware 1.0.4.15, which is still under testing.
Jason L Fri, 08/24/2012 - 14:45
Firmware 1.0.4.17 has been released, but the release notes do not show any fixes for this issue.  Was it not resolved?
Te-Kai Liu Sat, 08/25/2012 - 15:30
It is probably an omission. The fixes in 1.0.4.15 are carried over to 1.0.4.17 by default.
Related Content
