887VAG2 encapsulation slip
May 8th, 2012
Hi All
I have a problem to get the 3g interface to work, attached it's a configuration and an output for a debug chat.
The 3g interface dont support ppp and it only support slip, with slip I can't configure username and password becauseslip dont support authentication.
my second issue is the chat fails, it's indicated on the debug output attached.I need to know the following:
- how can I configure the username and password for this connection?
- is it possible to enforce ppp encapsulation?
- when to choose to use the virtual-template or a dialer string?
kind regards
Mpho
mavespig Thu, 05/10/2012 - 01:03
  • Silver, 250 points or more
Hi, can you post what was the original IOS and what is the new one? It will be helpful to other people facing the same issue.
Did the IOS upgrade fix both issues?
Marco
I am having a similar problem to you with a Vodafone 3G SIM in my Cisco 887VAG+7. I have uppgraded to 15.2(3)T from an earlier release but still can't get the problem resolved.
Was the only thing you did was the upgrade? Was there no other configuration other that what you have attached to the case?
Greg
mailaglady2 Fri, 06/22/2012 - 13:22
Hi Greg
Sorry for this late response, I never had a chance.
Is your problem sorted now?
Kind regards
Mpho
Thanks for the email. I did get this working in the end. I have shared the important bits of the configuration.
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
controller Cellular 0
interface Cellular0
description Vodafone 3G Network
ip address negotiated
ip nat outside
ip virtual-reassembly in
zone-member security Outside
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 2
async mode interactive
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
speed 237000
ip nat inside source list NAT-OUTBOUND interface Cellular0 overload
access-list 101 permit ip any any
dialer-list 2 protocol ip list 101
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
speed 237000
Greg
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
