Warning message
Routing two different networks over one interface using an HWIC on a 2811
May 8th, 2012
hello below is my configuration for my router. I have enabled ip routing as well and rebooted my router.
Here is what I can do.
1) I can ping the 10.0.33.x network from the 192.168.123.x network
2) I can get out to the internet using 192.168.123.x network VIA fa 0/2/0
What  I CAN NOT do
1) get out to the internet from 10.0.33.x network. using GW 192.168.123.253?
2) also is it possible to somehow keep this config and route my 10.0.33.x network out int fa 0/0.34 if I put it on a sub interface?
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/2/0
description to firewall
switchport access vlan 123
no ip address
interface FastEthernet0/2/1
description to PC Netowrk 2960 switch fa 47
no ip address
duplex full
speed 100
interface FastEthernet0/2/2
description to PC Network 2960 switch fa 48
no ip address
duplex full
speed 100
interface FastEthernet0/2/3
description to server network
switchport access vlan 33
no ip address
duplex full
speed 100
interface Vlan1
no ip address
interface Vlan33
description server network
ip address 10.0.33.2 255.255.255.0
no ip-redirects
interface Vlan123
description PC network
ip address 192.168.123.1 255.255.255.0
no ip-redirects
router ospf 100
log-adjacency-changes
network 10.0.33.0 0.0.0.255 area 0
network 192.168.123.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.123.253
ip http server
access-list 101 permit icmp any any
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
p.mcgowan Tue, 05/08/2012 - 08:12
  • Bronze, 100 points or more
do you have a route back to 10.0.33.0/24 from your gateway/firewall?
make sure you have a route in your gateway which will point to the 10.0.33.0/24 network, something like this;
ip route 10.0.33.0 255.255.255.0 192.168.123.1
j.pewarski Tue, 05/08/2012 - 08:21
Yes I do believe I have a route back
when I enter the static route
%Invalid next hop address (it's this router)
should I try my gateway .253 which is my firewall? instead of .1
shouldent OSPF handle this since I have both networks enabled on OSPF?
j.pewarski Tue, 05/08/2012 - 08:30
Are you talking about putting the ip route statement
in the firewall?
p.mcgowan Tue, 05/08/2012 - 08:32
yes, the firewall needs to have a route back to the 10.0.33.0/24 network
Related Content
