Teardown missing for built inbound connection on Cisco PIX 6.3
May 8th, 2012
In my syslog server configured for Cisco PIX 6.3,
I see lot of Built and teardown connections.
Logic says if something is built then there should be a teardown.
But I do not see teardowns for some connections even though I know that path is already broken long time ago.
See below.
May  3 09:44:16 ::ffff:204.50.68.253 May 03 2012 12:50:32 cfwprd1a : %PIX-6-302013: Built inbound TCP connection 954594374 for dcn:10.199.58.15/33646 (10.199.58.15/33646) to dmz:172.16.169.238/443 (204.50.68.235/443)
Why is there no teardown for the above in my syslog server?
And this is not just one - there are many meesages that do not have teardowns.
varrao Tue, 05/08/2012 - 11:39
Hi Kunal,
Check the following, I guess you migth have this message diasable, check:
show run logging
if it is:
no logging message 302014
then apply:
I guess you might have this log suppressed on the ASA.
Varun
Security Team,
Cisco TAC
kunal-united Wed, 05/09/2012 - 04:10
Please check this.
logging on
logging timestamp
logging standby
logging monitor debugging
logging buffered warnings
logging trap informational
logging history critical
logging device-id hostname
logging host dcn 204.50.69.3
logging host dcn 204.50.69.228
logging host apps 10.10.192.82
no logging message 106023
varrao Wed, 05/09/2012 - 07:19
Hi Kunal,
Can you filter your syslog server for the connection ID 954594374?? Moreover, are you able to see the Teardown in the ASDM log viewers, and the ASA log buffer? Can you also share the output of "show logging-queue"??
Varun Rao
Security Team,
Cisco TAC
kunal-united Wed, 05/09/2012 - 08:19
# sh logging queue
        Logging Queue length limit : 512 msg(s), 6251808 msg(s) discarded.
        Current 16 msg on queue, 512 msgs most on queue
I have all logs on the syslog server.
And I cannot see teardowns for few connections that were built.
