Does option 43 matter ? WLC5508 ver 7.2 using internal DHCP server
Answered Question
May 8th, 2012
I am using a WLC 5508 and its internal DHCP server. I cant find anywhere I can setup option 43. However, the access points are connected in just fine. Do I need to worry about setting up a seperate DHCP server to get option 43 setup properly ?
Thank you.
Correct Answer by Stephen Rodriguez about 4 years 10 months ago
If you want to have AP on a different subnet from the WLC, then yes you would want to configure another server and option 43.
If you're fine wtih your current setup, then no.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Overall Rating: 5 (1 ratings)
Scott Fella Tue, 05/08/2012 - 12:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Option 43 is to help the APs join the wlc. Your APs already are joined and this isnt used by clients.
Scott Fella
Sent from my iPhone
Khoa Pham Tue, 05/08/2012 - 13:02
Sorry I didnt make my question clear.
When I connect a CAPWAPP Access Point to the network, it receives IP address from the WLC 5508 DHCP service just fine. It shows up in the access points list and users can connect to it no problem.
Correct Answer
Stephen Rodriguez Tue, 05/08/2012 - 13:04
  • Purple, 4500 points or more
HTH,
Steve
Khoa Pham Tue, 05/08/2012 - 13:10
Stephen,
I want to rate your answer is a correct answer.
Do you any chance have a doc from Cisco saying this?
Khoa Pham Tue, 05/08/2012 - 13:18
Option 43 to join specific Wireless LAN Controllers (WLCs) when the WLC is in a different subnet than the LAP.
Awesome! Thank you.
Scott Fella Tue, 05/08/2012 - 13:05
  • Hall of Fame,
    2017 Wireless
You don't new option 43. The internal dhcp doesn't allow you to create any options, just default dhcp requirements.
Scott Fella
Sent from my iPhone
Related Content
